Ste-1241683 Posted February 5, 2022 Share Posted February 5, 2022 We have just set up an Arc Pro system in our office. We have a custom track which is approx 25m. We connected it all up and had led's on the red and green ports on the arc pro unit. The problem is, only 1 car will run on the track with the red controller. The green controller is registering on the app so when you pull the trigger, the percentage shows 100 %, but the second car doesn't move. So essentially, we have 1 car and 1 controller that is working. Any help would be greatly appreciated. Link to comment Share on other sites More sharing options...
Andy P. Posted February 6, 2022 Share Posted February 6, 2022 Hi & welcome,It would help to understand whether you bought ARC PRO as part of a set (and in that case which set) or if you added an ARC PRO poewbase into a layout you made up yourself.Do the cars actually have digital chips installed?25 Meters is VERY long. You must have 2 power supplies and you you must make sure the connections are very good: See Power drops and breaks: https://uk.scalextric.com/community/advice/track-maintenanceYou likely have the pairing of the cars mixed up. Woodcote, a contributor here figured out a "rule of 3" that is highlighted here:https://slotracer.online/community/showthread.php?tid=181Check all that out and please let us know how you get on. Link to comment Share on other sites More sharing options...
