Geronimo13 Posted February 28, 2022 Share Posted February 28, 2022 I wish to use HM 6010 for turntable operations but how do i control locos on & off turntable if it only controls the turning of it. Link to comment Share on other sites More sharing options...
96RAF Posted February 28, 2022 Share Posted February 28, 2022 You drive the TT rotation from Port 4 of the HM6010 and you drive the loco on and off using one channel of an HM6000 connected to the TT inlet road.Note that only Port 4 can be used as it has the extra oomph to drive the TT motor.Edit - unfortunately it only drives the TT one way as there are only 2-wires to the motor, so at present there is no way to swing it back if you overshoot unless you wire in a reversing switch. Link to comment Share on other sites More sharing options...
