K-1248780 Posted May 8, 2022 Share Posted May 8, 2022 Several Question actuallyIs there a hand controller for the spark plug app?Can I go digital with a spark plug set? (cars and track)I am assuming if I buy a digital arc pro I can add the digital chip to the cars and I am all set. Link to comment Share on other sites More sharing options...
Andy P. Posted May 9, 2022 Share Posted May 9, 2022 Hi There and welcome.The whole point of Spark Plug is the APP-enabled interaction. You use a smart device to control not only speed and braking but also other events like pitstops or affecting the other driver.It is more like adding an arcade game layer on top of regular racing.I am not sure what is meant by "going digital" with spark plug. The two systems are pretty much mutually exclusive from a technical point of view. The same as diesel and petrol/gasoline. They overlap in some cases but really can't work together.ARC PRO has all the features you need for realistic racing.More info is here:https://uk.scalextric.com/community/advice?support_advice_type=all&page=1Read through the differences between the systems so you don't buy something you don't need or won't work.Good luck! Link to comment Share on other sites More sharing options...
K-1248780 Posted May 20, 2022 Author Share Posted May 20, 2022 Andy Thank You So I bought the batman joker 1:32 set and obviously if I desire to build my own track can I add the arc pro power base to get lane changing and 6 car racing. If another power base offered that I would be good as well. Link to comment Share on other sites More sharing options...
