Keith-1249801 Posted June 26, 2022 Share Posted June 26, 2022 HiTotally new to scalextric. I have just upgraded to Arcpro. The issue i have , is that on joing the 2022 Scalextric Club it came with a Ford Mk11 Escort , then noticed on the back of the display case it said 12v.Will this work on Arcpro.Apologiesif this has already been mentioned. Thanksfor your time RegardsKeith Link to comment Share on other sites More sharing options...
Andy P. Posted June 27, 2022 Share Posted June 27, 2022 ARC PRO is the premier digital system from Scalextric: https://uk.scalextric.com/community/advice/app-race-control(see bottom of the page)ARC PRO also has an analog mode that makes it work exactly as ARC AIR (see middle of the page above).Your Club car (and pretty much any car of any manufacture in 1/32 scale) will work fine in ARC AIR mode.If you want to take advantage of digital racing you will have to add a digital chip to the car. This means either using a Digital Ready Plug (DPR) or the retro-fit chip . The package of the car will indicate if it is DPR. If it is not it will need the retro-fit chip. Link to comment Share on other sites More sharing options...
