James-1253486 Posted July 9, 2022 Share Posted July 9, 2022 Hi Legends,Need a bit of help if anyone can - long-time Scalextric fan, but just made the jump to a digital set. My analogue controllers have speed limiting via a little controller on the side that can be adjusted with a screwdriver. This is great for my kids (7 and 3) who otherwise just go too fast and crash. I've tried finding such a setting in the APP but I'm having no luck - does this exist in digital or not? I picked up an ARC Pro controller with the Le Mans 48 set. Honestly I need it also, the cars are so ridiculously overpowered they just fly right off the first corner with even the tiniest hint of pressure applied to the throttle. Any help much appreciated ... :)Many Thanks,James Link to comment Share on other sites More sharing options...
Andy P. Posted July 10, 2022 Share Posted July 10, 2022 Hi James,A couple of things:You can sett the maximum amount of power for each car for each race before starting.You can also create car profiles and set those setting as well.Digital cars with digital chips will be very very touchy in analog mode. The digital chip does a bad job of controlling the power flowing.I recommend reading this to get the most out of ARC PRO:https://slotracer.online/community/showthread.php?tid=181Andy goes though all kinds of setting that are not easily found in the quick start guide... Link to comment Share on other sites More sharing options...
