Speed issues
Hi, I'm having issues with a bachmann class 20 with a zimo decoder on railmaster with elink. Currently it has 2 speeds, at 1-3mph on throttle its a crawl, anything over 3mph it goes to full speed (and I mean full warp 9.9) and ends up coming off track. I have checked speed cvs, and cv29 that speedsteps are correct but nothing seems to make a difference. I have tried the loco on another brand controller on another layout and it works perfectly. I have tried to delete and reinstall the loco 3 times as this worked previously and for others and for me previously. Any suggestions welcome?
Does anyone know if turning off the use default speed curves setting in the INI file would do anything (or would that cause problems elsewhere?
Someone suggested setting it up as a different class loco from the roster list but not sure what that would achieve?
All my other decoders are ESU and I have a programmer to set these us easily. I only have 1 hornby tts decoder which I don't run often.
