Richard001 Posted December 27, 2022 Share Posted December 27, 2022 Hi Everyone,Here is what I did. I opened my Arc Air unit and found the two leads that feed track 2 [green] and routed them through a double-throw switch. That way both leads are isolated from track 2 when the switch is off and track 2 is fully powered again when the switch is on.I drilled a small hole in the side of my Arc Air to mount the switch. With the switch off [ lane 2 isolated] and the Arc Air app set up for one driver, Rally tracks are possible! [no short circuit error]With the switch on you are back to the normal Arc Air un.See the photos below of my little 76 x 184 cm [30 x 72-inch] rally circuit on a folding table for apartment dwellers with limited space. Link to comment Share on other sites More sharing options...
