Rana Temporia Posted December 30, 2022 Share Posted December 30, 2022 Following a repair to a DMU I realised that I don’t have any spare thrust bearings left. I have the brass bearing holders, oil retaking pads and the clips but that’s it. I have measured one with my cheap callipers and it shows 2.2mm but I would have expected them to be an imperial diameter. I know I can buy them off eBay but there is also a supplier of industrial bearings and I can have 1000 for the cost of four genuine ones. Does anyone know the correct nearest metric size? I am thinking of going for 2.1mm but wondered if anyone else has done this or has a more accurate (vernier?) set of callipers that they could measure one with? Link to comment Share on other sites More sharing options...
96RAF Posted December 30, 2022 Share Posted December 30, 2022 Find a twist drill that fits the hole and vernier up the drill, much easier than trying to measure IDs with a calliper. Link to comment Share on other sites More sharing options...
Rana Temporia Posted December 30, 2022 Author Share Posted December 30, 2022 Thanks for that suggestion 96RAF, it looks like the nearest is 2.2mm which is a good fit and I also found my 2.1 and 2.2mm bits were in the wrong parts of the drill box! The armature shaft diameter also measures at 2.2 with the callipers. I know it will be an imperial measurement but that looks to be pretty close and I drill my BA pilot holes with metric drills from a chart on the internet. Looks like I may shortly have enough thrust bearings for several lifetimes of repairing Tri-ang motor bogies. Link to comment Share on other sites More sharing options...
Rana Temporia Posted December 30, 2022 Author Share Posted December 30, 2022 Unbelievably I was looking for something else and found a spec for the motor bogie which says the shaft is 3/32” diameter which works out at 2.381mm and is a standard ball bearing size so presumably that’s what Tri-ang used? It’d be interesting to see if the Kitmaster bogie used the same size as it apparently wasn’t a direct copy of the Tri-ang one??????? Looks like my callipers are slightly out by 0.18mm which I can live with at £2.99 with a spare battery for the measurements I need to do. It looks like 2.2mm ones are standard in a number of camera mechanisms. Link to comment Share on other sites More sharing options...
96RAF Posted December 31, 2022 Share Posted December 31, 2022 My digi-callipers have a metric-imperial switch, but show decimal “ not fractions so you still have to do the math.At work I dealt with bearings all the time and had several manufs CDs with their ranges as well a cross-ref charts from make to make. My bearings were a tad larger than loco motor ones at up to dinner plate outer diam. Link to comment Share on other sites More sharing options...
Rog RJ Posted December 31, 2022 Share Posted December 31, 2022 There are digital calipers available that can display fractional values.Example https://uk.banggood.com/DANIU-150mm-Stainless-Steel-LCD-Screen-Display-Digital-Caliper-6-Inch-Fraction-or-MM-or-Inch-High-Prec-p-1373616.html? Link to comment Share on other sites More sharing options...
Rana Temporia Posted January 5, 2023 Author Share Posted January 5, 2023 For information and an update. I received the bearings this morning and the 3/32” seem to fit perfectly so I now have a bag of 50 which should be more than I will ever need, although I do have a few motor bogies that are awaiting a full rebuild and I have no doubt that some of the bearings will magically evaporate off the tray I use. I could have bought 1000 for a couple of £ more but I will never need that many and thought it was a waste. Link to comment Share on other sites More sharing options...
