Too Tall Posted March 23, 2023 Author Share Posted March 23, 2023 Well, still got the "heck no" vibe everytime I had to go into the room, so Henry came out and gobbled it up blushI had a lot of fine grade in the mix, which I think wasn't helping me, so I ordered some more medium and will try again when that arrives. Link to comment Share on other sites More sharing options...
Too Tall Posted April 18, 2023 Author Share Posted April 18, 2023 Recently I have spent some time with some ballasting, a lot more to do.But mostly working on a few of the peco laser cut kits and a cheapie cardboard kit for terraced housing.I think a coat of clear is next for the laser kits, then a bit of dirtying ! Link to comment Share on other sites More sharing options...
Wryd Posted April 18, 2023 Share Posted April 18, 2023 Great layout, I am in the designing stage for mine and am not sure as to the best way to have the ability to turn my locos around . Link to comment Share on other sites More sharing options...
Singer33 Posted April 18, 2023 Share Posted April 18, 2023 I do like what you have done with the station building, is it two kits put together? Link to comment Share on other sites More sharing options...
Too Tall Posted April 19, 2023 Author Share Posted April 19, 2023 Yes 2 together and I switched the back and front walls around so the extension was all windows.I will have one engine parked one way round in the engine shed and another opposite, for the up and down lines, that way I avoid the need for a return loop or turntable !I just need to clarify if trains drove on the right or the left on dual lines ! Link to comment Share on other sites More sharing options...
Rallymatt Posted April 19, 2023 Share Posted April 19, 2023 @TT, on UK mainlines, trains run on the left line in standard operation Link to comment Share on other sites More sharing options...
Too Tall Posted April 19, 2023 Author Share Posted April 19, 2023 Cool, outer loop clockwise, thanks blush Link to comment Share on other sites More sharing options...
Rallymatt Posted April 19, 2023 Share Posted April 19, 2023 👍 Link to comment Share on other sites More sharing options...
Too Tall Posted April 21, 2023 Author Share Posted April 21, 2023 Work on the station area has begun, lots still to do but a little progress blush Link to comment Share on other sites More sharing options...
Rallymatt Posted April 21, 2023 Share Posted April 21, 2023 Platform surfaces were a mix of materials, asphalt was quite common on the types of station you are modelling, with stone or concrete edging. Did I see you had got some weathering powders? You could also try some dry brushing different shades to break up the uniform colour or do a couple of patches where repairs could be done. Link to comment Share on other sites More sharing options...
Too Tall Posted April 21, 2023 Author Share Posted April 21, 2023 Hi Rallymatt,, yes some dry brushing and rubbing now done as above.Possibly too subtle but enough to break up the uniformity I feel.Still learning lots of new things, and not all of it coming out how I imagined, (ballast case in point) but old dogs like me, take a while to learn new tricks blush Link to comment Share on other sites More sharing options...
Too Tall Posted April 22, 2023 Author Share Posted April 22, 2023 Work started today on modifying and assembling the factory building.This is going to be Millwood Pottery Co.As there was only one entrance and it was the wrong end, I needed to do some work to make it fit my layout.So some peco brick paviours were utilized to be the builders modification to the original Victorian factory brick work.Now we have an interior platform for loading goods out onto wagons, the original platform on the end will be the coal in for the furnace, I will need to make a door or double door in the wall so the offloaded coal can be barrowed into the factory furnace at the other side of the building.Original factory plan is as below:and the basics are in, arch knocked through, extended goods in/out managers office and loading platform fitted, one external door opening bricked up, and door moved to open onto platform.I will do some closed double doors on the interior wall for outgoing products. I was thinking of a roller door, but I am not sure they were commonplace in late 40's early 50's?!Obviously the joins need some tidying up, but all in due course ! Link to comment Share on other sites More sharing options...
Too Tall Posted May 7, 2023 Author Share Posted May 7, 2023 And the nearly finished factory ready for the layout.(it is now, since pic was taken matt clear coated the brown roof ends and supports). Link to comment Share on other sites More sharing options...
Rallymatt Posted May 7, 2023 Share Posted May 7, 2023 This is looking fantastic, love the level of grime Link to comment Share on other sites More sharing options...
taunmarc88 Posted May 8, 2023 Share Posted May 8, 2023 That really does look amazing, it’s going to add so much life to the layout. Link to comment Share on other sites More sharing options...
Too Tall Posted May 8, 2023 Author Share Posted May 8, 2023 Cheers guys, still learning techniques etc, so way off the experts, but I am happy with it. Link to comment Share on other sites More sharing options...
Chris98 Posted May 8, 2023 Share Posted May 8, 2023 Very nice 👍 Link to comment Share on other sites More sharing options...
Artyp Posted May 9, 2023 Share Posted May 9, 2023 Very good. Wish I had that much space! Link to comment Share on other sites More sharing options...
Too Tall Posted May 9, 2023 Author Share Posted May 9, 2023 No matter how much space you have, you always want more ! Link to comment Share on other sites More sharing options...
Too Tall Posted May 15, 2023 Author Share Posted May 15, 2023 Finally, I have completed the ballasting, time to start the scenery ! Link to comment Share on other sites More sharing options...
Rallymatt Posted May 15, 2023 Share Posted May 15, 2023 You have got a lot done! Link to comment Share on other sites More sharing options...
Too Tall Posted May 18, 2023 Author Share Posted May 18, 2023 Basic terraforming has begun.The snippet of passing branch line will be the programming track for DCC when I switch over. Link to comment Share on other sites More sharing options...
Dodge1965 Posted May 18, 2023 Share Posted May 18, 2023 Wow... Looks real good, is it removalable? Link to comment Share on other sites More sharing options...
Too Tall Posted May 18, 2023 Author Share Posted May 18, 2023 Yes, the fixed supports are made from 2 layers of 30mm foam board. The top section is one piece of 30mm foamboard with some other foam board shapes roughing out the elevation changes and rocks. The top board can be lifted off for track cleaning or incident rescue !I just hope when I add the plaster cloth, it doesn't add too much weight as its very light right now grinningEventually it will be the location for a Church and graveyard, and a Shepard's cottage. Link to comment Share on other sites More sharing options...
Dodge1965 Posted May 18, 2023 Share Posted May 18, 2023 Thanks for that, i'm looking to do the exact same, but have zero skills at this type of thing.. Link to comment Share on other sites More sharing options...
