lee-1287402 Posted February 11, 2023 Share Posted February 11, 2023 Track Day ArcAir set. neither controller will power up lane 2 with any car. lane 1 works fine w both controllers. help please and thanks in advance! Link to comment Share on other sites More sharing options...
Andy P. Posted February 12, 2023 Share Posted February 12, 2023 Hi Lee,Thanks for checking that it`s not the controllers.You can inspect thepwoerbase without voiding the warranty: Carefully unplug the the powerbase. Ideally let it set for a few hours or overnight as there might be capacitors inside that will hold a charge.Remove the screws in the powerbase. I don`t think they are different lengths but if they are try to note where they all go.Visually inspect that everything looks ok. Culprits would be wires that are not attached (either because they are unplugged, or the plug is not pushed "home" or the solder seems to be faulty.Also look for since of broken wires, overheating/burning.If all of this looks OK then close it up and contact Customer Support using the link at the bottom of this page. They should be able to helpWith any luck just a cable has come loose and by pushing it back in you can get it to work again.Good luck! Link to comment Share on other sites More sharing options...
lee-1287402 Posted February 12, 2023 Author Share Posted February 12, 2023 THANKS!! black wire had pulled loose. pushed it in and running! glad don't have to send it anywhere Link to comment Share on other sites More sharing options...
Andy P. Posted February 13, 2023 Share Posted February 13, 2023 That is awesome!Happy racing! Link to comment Share on other sites More sharing options...
