Coaster Posted April 23, 2023 Share Posted April 23, 2023 Hi alli recently purchased a platinum pro gt (2020) set which comes with four cars:Aston Martin Vantage GT3Bentley Continental GT3Ford Mustang GT4Mercedes-AMG GT3Please could someone recommend which additional two cars in the range would compliment these four in terms of style/size?many thankstom Link to comment Share on other sites More sharing options...
Andy P. Posted April 25, 2023 Share Posted April 25, 2023 Hi TomFor some technical reason your other posts with pictures as well as my response(s) are not showing u...IN any case: Any GT car should perform the same as long as it is the same motor conifguration and same type of motor.Hornby cars are mostly "inline" i.e. motor perpendicular to the rear axle or sidewinder i.e. motor parallel to the rear axle. The motor is a fairly standard 13D Mabuchi motor.There is a GT40 car that uses a thinner motor that has higher revs and will behave quite a bit differently.Using the ARC APP you can adjust acceleration and top speed to make the cars compatible as well... Link to comment Share on other sites More sharing options...
