Mark-355956 Posted May 11, 2023 Share Posted May 11, 2023 wouldnt it be great to play slot cars alone aswell as with others, well i have designed a pace car system that is so easy, the slot switches a microswitch left and right , and trigers different power setups with resistors, this is like the variable trigger resistor you use but with a fixed resistance so it slows down on corners, see image attached. Link to comment Share on other sites More sharing options...
Mark-355956 Posted May 12, 2023 Author Share Posted May 12, 2023 it has a microswitch that is triggered when the slot car is on a bend so it can slow down, its very simple mod alot of home users could do. the power from the controler is set on full, then the track to motor wire is diverted through the microswitch on the car then through a resistor cutting power, this enables the car to run on its own and slow at corners Link to comment Share on other sites More sharing options...
David-357935 Posted June 1, 2023 Share Posted June 1, 2023 Here is a pace car system I built some years ago...https://www.youtube.com/watch?v=zYki7rpQMYU&t=209s Link to comment Share on other sites More sharing options...
Mark-355956 Posted June 5, 2023 Author Share Posted June 5, 2023 that was cool, i like your track too Link to comment Share on other sites More sharing options...
