Train novice Posted July 22, 2023 Share Posted July 22, 2023 Good afternoon was wondering if anyone now how you change the speed of the loco on the hornby elinkThank you Link to comment Share on other sites More sharing options...
P-Henny Posted July 22, 2023 Share Posted July 22, 2023 Your question relates to Railmaster software, not DCC, hence why a mod has moved it here.Far more in depth detail of the issue you're experiencing is required when the query you have relates to a software driven control system like Railmaster.Your question as written is too vague. You need to be more specific regarding what you mean by your question.a) Are you asking how to change the speed of the loco on the track i.e How to use the Railmaster throttle panel.ORb) Are you asking how to make the full speed of the loco faster or slower when using the full travel (max speed) of the loco throttle slider in the Railmaster software.ORc) Are you asking how to fix the known documented problem of the speed control being 'all' or 'nothing' with no graduated control inbetween.ORd) Are you asking about something else entirely different.Is your issue related to only one single loco or all your locos. If one loco, then what loco is it?Knowing exactly what the issue is that you have allows you to be given the most appropriate advice.For example, b) & c) above have been resolved in forum advice before and have documented solutions that can be given to you. Link to comment Share on other sites More sharing options...
