Y-353672 Posted September 13, 2023 Share Posted September 13, 2023 Hi,I need a bit of advice. I have been making models aircrafts for sometime now,but I do not know how to paint the window frames as paint brushes are too thick.Would somebody tell me how to do this?Thanks Link to comment Share on other sites More sharing options...
Ratch Posted September 13, 2023 Share Posted September 13, 2023 For some kits, paint masks are available. You can use masking tape and cut it yourself, or use a paint brush with a fine. pointed tip. Link to comment Share on other sites More sharing options...
peebeep Posted September 13, 2023 Share Posted September 13, 2023 As Ratch says, use masking to achieve a sharp edge. I use yellow washi type tape cat into thin strips. If you want to have a go at freehand painting use liner brushes with long bristles, this helps achieve straight lines. If you do an eBay or Amazon search you'll find them in the nail art sections and you can pick them up cheap as chips. Link to comment Share on other sites More sharing options...
Topcat_Ern Posted September 14, 2023 Share Posted September 14, 2023 Remember the humble cocktail stick. Any overpaint can be scratched away leaving a neat line if the framing on canopies is proud.Andy Link to comment Share on other sites More sharing options...
