Ian-364932 Posted September 18, 2023 Share Posted September 18, 2023 Might be a daft question but i’m getting to the part of my model which requires me to insert a clear plastic instrument panel into the cockpit. This will need painting black & then decals applied after for the instruments.My question is, do i need to prime the clear plastic part first as per the rest of the kit or is it best to just airbrush the black colour straight on ?I will be using Humbrol Acrylics.Thx Link to comment Share on other sites More sharing options...
peebeep Posted September 18, 2023 Share Posted September 18, 2023 It depends how much you expect to handle the part. I have little faith in aqueous acrylic being able to have good adhesion onto bare plastic, especially a transparency, so I would prime. If you use a black primer you can kill two birds with one stone. Link to comment Share on other sites More sharing options...
Ratch Posted September 18, 2023 Share Posted September 18, 2023 I usually paint the interior colour on the framing, then over-paint with the exterior colour. That way, if the frame is viewed through one side it should appear to be the right colour. Link to comment Share on other sites More sharing options...
