Sid001 Posted October 23, 2023 Share Posted October 23, 2023 Can the TSS decoder be used on dc power onlyand if so what is the minimum votage required?Or to put it another way could a TSS decoder be used from 5v usb supply? Link to comment Share on other sites More sharing options...
P-Henny Posted October 23, 2023 Share Posted October 23, 2023 No such thing as a TSS decoder, there are however TTS and TXS decoders. So which one did you mean with your typo.TTS - No support for sound at all on an Analogue DC track. Analogue DC control support in CV29 is also disabled at the factory.TXS - Sound is available under Bluetooth control when placed on a DC powered track. Note that DC in this scenario is not the same as Analogue control.The TXS decoder can be powered from DC when in its Bluetooth [pseudo DCC] control mode. The TXS decoder when DC powered would prefer a supply greater than 5 volts and preferably 12-15 volts pure DC. Analogue DC control support in CV29 is also disabled at the factory for the TXS as well, else the Bluetooth control under DC track power wouldn't work. Link to comment Share on other sites More sharing options...
