ArnoldAmbrose Posted January 28 Share Posted January 28 Gidday All, like many here I much prefer the 1/600 scale in model warships. When I restarted modeling about 25 years ago I recommenced where I'd left off as a kid - with Airfix 1/600 scale ships and I've pretty much stayed with them ever since. But I'm running out of subject kits so I modify them now, to actual ships and also 'what-ifs', which I enjoy doing. When I do these I try to make them as plausible as I can. Most fans of RN WW2 ships will know of HMS Belfast. What some may not know is that the reason for her larger size over the other Town/Southampton subgroups is that it was intended that she and HMS Edinburgh be armed with sixteen 6-inch guns in four quad turrets. But a suitable turret couldn't be built AFAIK so they were ultimately fitted with improved triple turrets instead. But what if a suitable quad turret was developed after all? She may have looked something like I've made here. My model depicts HMS Belfast armed with sixteen 6-inch guns (4x4), eight 4-inch AA guns (4x2), four 40mm Bofors (4x1), sixteen 2lb pompoms (4x4) and twenty 20mm Oerlikons (4x2, 12x1). She also carried six 21-inch torpedo tubes and a chute of depth charges. To make the quad turrets I used two triples to make one quad. This made them rather large though, and required a lot of reshuffling of other structures.And to compare this model with the original OOB,Thank you for your interest. Regards to all, Jeff. Link to comment Share on other sites More sharing options...
Matt G Posted January 28 Share Posted January 28 Both versions look grand to me! Link to comment Share on other sites More sharing options...
