Steve-353799 Posted March 26 Share Posted March 26 Hello I've just found out you can fit a stay-alive into the TT120 08 Shunter without any modification! How to fit a Stay-Alive into a Hornby TT120 08 Shunter. Without Modification! - YouTube Cheers guys. Steve 1 Link to comment Share on other sites More sharing options...
Rallymatt Posted March 26 Share Posted March 26 You can get sound in too with a little bit of trimming of the decoder tray 😁 Link to comment Share on other sites More sharing options...
Fishmanoz Posted March 26 Share Posted March 26 The OP’s includes sound and the stay alive without modification. Although just how the capacitors fit isn’t shown as they were installed for him by Youchoos, if I remember the shop correctly. Link to comment Share on other sites More sharing options...
Rallymatt Posted March 27 Share Posted March 27 (edited) I must have been tired from all the drystone walling at High Fell! I looked to see if it said sound and somehow missed it completely! I am considering upgrading my Black 08 to sound, so this is interesting 😁 Edited March 27 by Rallymatt More spilling areas…errors Link to comment Share on other sites More sharing options...
Fishmanoz Posted March 27 Share Posted March 27 Maybe if you started with the title? Link to comment Share on other sites More sharing options...
Rallymatt Posted March 27 Share Posted March 27 Missed it, the downside of a small screen. Link to comment Share on other sites More sharing options...
Steve-353799 Posted March 27 Author Share Posted March 27 Thanks Guys. Yes, indeed sound is fitted and I went for the sound download from Digitrains end of the day (Protodrive) as the sound from Youchoos and Coastaldcc aren't that good in my opinion they sound tinny. The service from Youchoos was first rate they even swapped the original decoder as it appeared to be faulty and their communication pipeline is second to none. It was John from Youchoos who told me that Zimo insists on an antistatic wristband to be worn when handling their decoders. The 3 staco's fit at the back of the chassis and the charge plate goes over the worm drive at the front. The staco's fit vertically. If you enlarge the photos that Digitrains sent me you can make it out even though the photo shows 2 staco’s. So I would think 2 would easily fit! by the way I take it that this new forum doesn't have a spellchecker? Cheers! Link to comment Share on other sites More sharing options...
Rallymatt Posted March 27 Share Posted March 27 That’s a lot packed in, tempting indeed 😁 1 Link to comment Share on other sites More sharing options...
ateshci Posted March 27 Share Posted March 27 (edited) Just to set term usage right: 'Staco3' is the pcb (2nd photo, RH) that contains a step-up converter to supply a CONSTANT 10V taken from the small 0.3F 'supercaps' (2nd photo, LH). If two are fitted, they charge to ~5V. The effective capacity is 0.15F. The stored energy is 1.875 Wsec, of which according to ZIMO 1.2 Wsec can be used. Buffering time is ~1.5sec, which is fine to overcome even the worst dead spots. Charging time between two contact losses with total drain is ~30sec - so don't overdo shoddy track state! Here's an example of what I did, using a prismatic capacitor of 0.47F, later replaced by two 0.3F ones: The step-up converter sits vertically under the decoder. Edited March 27 by ateshci 2 Link to comment Share on other sites More sharing options...
Steve-353799 Posted March 28 Author Share Posted March 28 Hi Guys here is a new Youtube link. Hopefully I've made the fitting of the Staco's a bit clearer. Thanks How to fit a Zimo sound decoder and Stay-Alive into a Hornby TT120 08 Shunter. Without Modification! - YouTube Link to comment Share on other sites More sharing options...
