Ignorant dad with multiple circular tracks that won't work
Inner and outer loops have inverted polarity.  When you switch the points, you create a dead short.
You need to have same polarity on inner and outer loops.  I can see the track clip is 180° out inner vs outer.  Insert track clips from same side (outside or inside).
Also, it is not terrific practice to have two independent power supplies cross connected.  They need to be isolated
  Put insulating fishplates (track connectors) between the points that take you from inner to outer loop
Bee
  • Like 1
