Ratch Posted April 16 Share Posted April 16 Some of you may know that quite recently I built the old 1/72 Matchbox Walrus. It will be interesting to see how the hobby has advanced over the 44 years between the issue of these kits. Of course, with the Airfix kit being 1/48 scale we can expect greater detail, but what about the basics? I will be building straight from the box, but using consumables I have to hand, and corrections to colours I deem necessary, rather than sticking with those specified. I intend to build option B, a Mk. I of 700 NAS, HMS Sheffield, 1941. Link to comment Share on other sites More sharing options...
john redman Posted April 16 Share Posted April 16 I built a 1/72 Walrus years ago too but I can't remember whether it was the AFX one or the MBX. Either way, they're a bit pricey now so the sooner AFX issue the Walrus in 1/72 scale the better. Link to comment Share on other sites More sharing options...
Ratch Posted April 19 Author Share Posted April 19 Before starting the build I airbrushed all the interior surfaces with Tamiya XF-71 Cockpit Green while still on the runners. Details were picked out with a brush. Link to comment Share on other sites More sharing options...
Ratch Posted April 22 Author Share Posted April 22 The interior detail is exquisite in quarter scale and the hull is crammed with it. Link to comment Share on other sites More sharing options...
Ratch Posted April 23 Author Share Posted April 23 I was a little apprehensive cutting the spar from the hatch in step 18, but as I’d allowed the glue to fully cure, the cut was simple and clean. Just a run over with a file removed the burrs showing. The transparencies were fixed with G-S Hypo Cement and masked. Link to comment Share on other sites More sharing options...
Ratch Posted Friday at 18:52 Author Share Posted Friday at 18:52 Just a few decals added. Link to comment Share on other sites More sharing options...
Ratch Posted 59 minutes ago Author Share Posted 59 minutes ago I fitted the instrument panel and winch under the nose panel and then fixed that in position. A smear of filler was used on the joints. Link to comment Share on other sites More sharing options...
