retro fitting cars with front and back lights
Powersy
Is your question whether you can add lights to cars that don't normally have it or replace old lighting in cars that have it with new technology such as LED?
If the former then the best thing to do is to look for a "kit" with LEDs or go to an electronics store of your choice and explain what you want to do.
You will have solder a little bit but with practice it isn't horribly difficult.
Once you get the hang of it you can even solder in little "batteries" that will let the lights glow even after the power is off.
Replacing exsiting lights is pretty much the same just you won't have as much soldering to do.
