RailMaster Help Site - Updated
Update: 07 Oct 2023
The RailMaster Help Site has been updated somewhat with reference to the newer Windows 11 OS after a larger take-up and as it has begun to settle as an OS. Other software related updates are included and detailed throughout.
So… what will you find? Check these out:
  • The latest AntiVirus links to products unlikely to break RailMaster like Norton’s or McAfee’s for example… and they’re free
  • Preparing your system for RailMaster installation with Windows 11 (and earlier)
  • Installation - expanded - step by step with pop-up windows using CSS transitions
  • Tips and Tricks - additional details so RailMaster can be run with optimum options
  • RailMaster Pro - a list of benefits this adds to the standard edition of RailMaster
Plus...
  • Stuck with knowing which drivers to use?
  • What port should be allocated to RailMaster?
  • Which baud rate should be selected?
  • How to edit the RailMster.ini file
  • How to deactivate, install and then reactivate RailMaster
Other links on the Home Page give even more help. Some of which may be a little specialised but are easy to follow and grasp…
  • How to Solder - particularly for the model railway enthusiast (based upon a post by former Community Moderator Chrissaf)
  • Networking RailMaster
  • Learn how to use a fixed IP address and what they are
  • What is Binary and how is it used?
  • Transfer RailMaster from one computer to another
  • How to update the Elite
  • What cables to use and how to wire them - Ethernet
  • Need more amps but find a certain power adaptor expensive? Here’s an alternative
  • Want rid of the bloatware Microsoft place in Windows 10 and 11? Want to block their software transmitting data back to them? Check this out - Win 10 / 11 and Privacy
This thread will remain locked and fixed so if there are any queries arising from the site please start a new thread within the forum or e-mail me directly from within the site itself.
The link below will open a new window so you will not lose your place on the forum.
AugustusCaesar (AC)
Guest
This topic is now closed to further replies.
