The Spoggles Dad Posted June 28, 2015 Share Posted June 28, 2015 hi, thinking of getting a little Micro set for my kids (and me) to play with. Can the track be screwed down to a boRd to prevent me having to keep taking it apart? Link to comment Share on other sites More sharing options...
Andy P. Posted June 29, 2015 Share Posted June 29, 2015 I have sucessfully used Velcro since it often some to pass that we want to change the layout and screwing and unscrewing could damage the teh track /board and take time.There are special clips you can use the screw it downon the side though if you want make things more permanant:https://www.scalextric.com/uk-en/track-fixing-side-clips.html Link to comment Share on other sites More sharing options...
The Spoggles Dad Posted June 29, 2015 Author Share Posted June 29, 2015 Great, thanks very much for the reply. Having now been to a shop and looked at kits, I'm more thinking normal 1/32 size. More expandable if the boy gets into it Link to comment Share on other sites More sharing options...
Andy P. Posted June 29, 2015 Share Posted June 29, 2015 Yes there are many more options with SPORT sets... :-) Link to comment Share on other sites More sharing options...
The Spoggles Dad Posted June 29, 2015 Author Share Posted June 29, 2015 Thanks Andy, do you know if the mclaren MP4-12c set is sport? Link to comment Share on other sites More sharing options...
Andy P. Posted June 30, 2015 Share Posted June 30, 2015 see your other thread... Link to comment Share on other sites More sharing options...
Feendish Posted December 31, 2016 Share Posted December 31, 2016 If you wish to fix your track permanently to a board I have used the following method.Using a 1mm bit in a hand drill or small battery drill put two pilot holes in the end of each track section in the bottom of the actual guide slot, one hole in the left slot at one end and the other in the right slot at the other end....OK so far?Next position the track section in its final location, locking it to previous track.Push a 10mm brad (not a panel pin - the head is too large) into the pilot holes and gently tap down into the board using a thin punch or flat bladed screwdriver. Don't punch too far, (the slot may distort) just enough to get the head of the brad flush and stop the track moving. You can fit additional fixings wherever you wish, it will just take a while longer.If done correctly the car guide blades will clear the brad but in the event of the blade catching slightly you can remove half a millimetre from the blade with a craft knife with no effect on the car's performance.I have successfully used this method on a small pilot section of track and am about to build a full 32 square foot layout on an eight by four foot chipboard base. I will keep you posted on the progress. Link to comment Share on other sites More sharing options...
Feendish Posted December 31, 2016 Share Posted December 31, 2016 UPDATE........Simpler method discovered and tested !!On each track section you will notice two small indentations in the centre of the track at each end.Drill a 1mm pilot hole as above, fit 10 or 12mm brads through the track and punch down into base board. You will find that the head finishes flush with the track surface due to the indentation and will not impede the cars in any way.SORTED!! 😉 Link to comment Share on other sites More sharing options...
nicestuff2104 Posted July 25, 2018 Share Posted July 25, 2018 Hi, are you able to send a link for the 'Brad nails' you are talking about please? Many Thanks UPDATE........Simpler method discovered and tested !!On each track section you will notice two small indentations in the centre of the track at each end.Drill a 1mm pilot hole as above, fit 10 or 12mm brads through the track and punch down into base board. You will find that the head finishes flush with the track surface due to the indentation and will not impede the cars in any way.SORTED!! 😉 Link to comment Share on other sites More sharing options...
Andy P. Posted July 26, 2018 Share Posted July 26, 2018 Coud you post a picture of a "brad" ?Some users may not be sure what it is. :-)Thanks!Glad it worked out! Link to comment Share on other sites More sharing options...
nicestuff2104 Posted July 27, 2018 Share Posted July 27, 2018 Do you know what nail or screw would work well to pin down micro track to MDF? or tips... Cheers Coud you post a picture of a "brad" ?Some users may not be sure what it is. :-)Thanks!Glad it worked out! Link to comment Share on other sites More sharing options...
