markSandD Posted October 15, 2011 Share Posted October 15, 2011 Hi, can anyone help with this one at all?I am using the Hornby Sapphire Decoder in a locomotive which is fine. The problem I am having is that I cannot get the loco to run smoothly at lower speeds. The only way I can describe it is a kind of juddering as the loco is moving in either direction.I have tried to alter the settigs of the Decoder, 'back EMF', the 'acceleration level', I even tried it with the 'Shunting function' on and off , altering the 'back EMF' to a low level, makes the loco run smoothly at higher speeds, but the speed fluctuates, and the loco is difficult to get moving with a train behind it at higher speeds, and makes it very difficult to get moving at lower speeds.Anyone had experience of this issue before? Link to comment Share on other sites More sharing options...
Gregd99 Posted October 15, 2011 Share Posted October 15, 2011 when I saw the title I thought.... back-EMF.you have already tried this so I am at a bit of a loos.Did you set back-emf to 0?I had what sounds like the same problem with a Class 20 and an 8245. it was doing my head in and I though that the issue was mechanical. Setting back-emf to 0 fixed it. Link to comment Share on other sites More sharing options...
Fireman_Ian Posted October 17, 2011 Share Posted October 17, 2011 What Loco is it? I have the same problem with a Thompson L1 and Hornby told me that the motor is geared to run smoothly at higher speeds not low speeds?????? I tried all the decoder settings aswell but to no avail, so I have a loco which is pretty much useless. Link to comment Share on other sites More sharing options...
markSandD Posted October 18, 2011 Author Share Posted October 18, 2011 It is a Bachmann 7F 2-8-0Although having took the loco to pieces again for the 3rd time, I think it is a stiff chassis that is causing the problem, as under DC control, the loco needs a bit of a tweek with the control knob to get it moving. I am currently giving it more 'running in'. This could be the problem with your loco also? Link to comment Share on other sites More sharing options...
