mailmatt Posted October 18, 2015 Share Posted October 18, 2015 Hi AllI would like to know the minimum recomended measurements from the edge of base board to track edge, as I am building a layout in my shed,thanksmail matt Link to comment Share on other sites More sharing options...
37lover Posted October 18, 2015 Share Posted October 18, 2015 When I built my helix I used 33mm clearance from the centre of the track to the supports so 50mm should be adequate. I also have fitted 150mm high perspex upstands around my 'edges' to hopefully stop anything falling off but these are also useful to stop me damaging the layout when I lean over! Link to comment Share on other sites More sharing options...
walkingthedog Posted October 18, 2015 Share Posted October 18, 2015 Fix a strip of Perspex along the edges about 2 inches tall then you can go as close as possible and nothing can fall off. Things shouldn't fall off the track anyway, they might derail but not fall off. Link to comment Share on other sites More sharing options...
96RAF Posted October 18, 2015 Share Posted October 18, 2015 The way I read it the op was looking for clearance around the outside of the track to avoid hitting the shed walls.Advice above appears to be aimed at the inner edge of the boards.Different eyes see different things. Link to comment Share on other sites More sharing options...
walkingthedog Posted October 18, 2015 Share Posted October 18, 2015 Could be RAF, in that case it depends what your running. You might be advised to allow a large gap so you can add scenery. Link to comment Share on other sites More sharing options...
37lover Posted October 18, 2015 Share Posted October 18, 2015 Not quite RAF; Magfan and myself gave advice about general clearance, and I then added a bit about using perspex along any open edges which was in turn supported by WTD. Regardless of which edge the OP needs to know a clearance, what do you suggest? 50mm is good. If you can leave more it gives space to fill in with low relief structures/scenery to disguise the wall!Edit - WTD beat me to it. Link to comment Share on other sites More sharing options...
mailmatt Posted October 18, 2015 Author Share Posted October 18, 2015 Hi Allthank you for your help, the clearence is for shed wall to track, all ideas have been helpful. Link to comment Share on other sites More sharing options...
96RAF Posted October 19, 2015 Share Posted October 19, 2015 @37Lon my first layout here I used the pencil on my longest carriage (12 wheel restaurant car) technique to get my track as close to the edges as possible as space on the boards was limited and I (foolishly) wanted to cram as much track in as possible. this worked fine until I got a streamlined Coronation Pacific, which being rather portly at the front fouled on the minimal scenery on certain outside curves, requiring a difficult track rework. so in answer to the op and yourself now I always leave at least 25mm more than the pencil scribe suggests in the critical tight corners just to be safe, otherwise as much as I possibly can, as you say, the more room you leave the more scenery you can place. I also use a decent height stand up edge as a barrier against excursions to the floor, 150mm is my normal face side 'skirting board' aligned 25mm down from the baseboard bottom edge to allow clearance to avoid wiring being snagged by my roll out cupboards. Link to comment Share on other sites More sharing options...
