Paul10470 Posted October 26, 2011 Share Posted October 26, 2011 Can anyone help, i bought the dcc sound class 50037 and is running very slow even full power ,alsi the horn functions on f2 and f3 stick on and have no control ,any ideas Link to comment Share on other sites More sharing options...
58001 Posted October 26, 2011 Share Posted October 26, 2011 This is not normal behaviour! I should contact Hornby customer care or the shop from where you bought it. Link to comment Share on other sites More sharing options...
poliss Posted October 26, 2011 Share Posted October 26, 2011 What controller are you using? Link to comment Share on other sites More sharing options...
Paul10470 Posted October 26, 2011 Author Share Posted October 26, 2011 [reply]poliss said:i am using the hornby ellite which i bought at the same tame as 50037 Link to comment Share on other sites More sharing options...
Blackbird Posted October 27, 2011 Share Posted October 27, 2011 I would try setting the decoder to 'factory default settings'. Available from your controller, see instruction sheet. Hope that is of help. Link to comment Share on other sites More sharing options...
RobF Posted February 14, 2013 Share Posted February 14, 2013 Hi - did you get a fix for this? I know this thread is ages old, but I've just picked up a 50 and have the same issue.thanks Link to comment Share on other sites More sharing options...
poliss Posted February 14, 2013 Share Posted February 14, 2013 New or second hand? If second hand then have you tried resetting the decoder as mentioned? Link to comment Share on other sites More sharing options...
RobF Posted February 14, 2013 Share Posted February 14, 2013 Hi.. 2nd Hand. Yes, I reset the decoder and I dropped the seller a query.Interestingly, said it did run slow but bought a Hornby dcc controller and it ran fine. Previously NCE PowerCab - which is the same as I have. Just wondering if there is a setting that needs adjusting - perhaps specifically for NCE. I've checked the usual suspects. I've also dropped Loksound an email as it's their v3.5 chip in there. I haven't really found many other issues like this on the Web - one other on another forum. Link to comment Share on other sites More sharing options...
Gregd99 Posted February 16, 2013 Share Posted February 16, 2013 have a look at teh CV values related to speed. Is the decoder using the speed table (check CV29 bit 4 in www.hornby.com/filelibrary/download/?FileID=186)? if yes then check the values in teh speed table (CV67-96).much more likely is that it will be using CV2,5,6 where CV5 sets the maximum speed.reading the loksound documentation shows that CV5 has a range 0..64 and a default value of 64. Form my reading of the nmra spec this CV can have a value up to 255 (=4 x 65). I have also seen some discussion on this forum on the same topic.so.... try setting CV5 to 127 and see if there is any change. have a look also at https://www.hornby.com/forums/hornby-forums/hornby-digital/4272/?page=2#post48653 Link to comment Share on other sites More sharing options...
