JWRStation Posted February 23, 2016 Share Posted February 23, 2016 I have RM and E link with the standard 1 amp transformer. I require to control and operate sound on up to 10 loco's which trips out as the transformer connot supply the required amperage. There is a 4 amp power supply available but it is not clear if this can just be plugged into the e link in order to run up to 4 amps through the e link or, if the additional power module is required between the e link and the track. JWR Link to comment Share on other sites More sharing options...
Fishmanoz Posted February 23, 2016 Share Posted February 23, 2016 JWR, remove the 1Amp and replace it with the 4. Track connection doesn't change. Will be obvious when you actually see it. Link to comment Share on other sites More sharing options...
Chrissaf Posted February 23, 2016 Share Posted February 23, 2016 Plus, if you actually look at the P9300 product page you will see that this PSU is specifically stated as being a replacement 4 amp power supply for the eLink one. Link to comment Share on other sites More sharing options...
GWR Greg Posted February 23, 2016 Share Posted February 23, 2016 I have a 4amp power supply with my elink. Link to comment Share on other sites More sharing options...
96RAF Posted February 23, 2016 Share Posted February 23, 2016 And if you read the RM manual it also talks to using the 4 amp PSU with the eLink when you have over many locos to run - so JWRStation less time playing trains and more study time on the manuals. Link to comment Share on other sites More sharing options...
JWRStation Posted February 23, 2016 Author Share Posted February 23, 2016 Thanks to all but a simple yes or no would have sufficed....JWR Link to comment Share on other sites More sharing options...
96RAF Posted February 24, 2016 Share Posted February 24, 2016 Tongue was firmly in cheek when I posted that reply JWRS 😉 Link to comment Share on other sites More sharing options...
JWRStation Posted February 24, 2016 Author Share Posted February 24, 2016 Hi RAF So was mine...!!! I Had read the manual and it talked about the elite this and elite that , must have got bored before the last line of the paragraph which mentioned the e-link. As is said RTFM, cheers to all.JWR Link to comment Share on other sites More sharing options...
Fishmanoz Posted February 24, 2016 Share Posted February 24, 2016 JWR, members here are very reluctant to give simple yes/nos, although I got my reply on one only line. Link to comment Share on other sites More sharing options...
96RAF Posted February 24, 2016 Share Posted February 24, 2016 JWR, members here are very reluctant to give simple yes/nos, although I got my reply on one only line. As seen above Fishy it rolls over onto two. It all depends upon your screen set up - you must have the 32" iPad. Link to comment Share on other sites More sharing options...
Fishmanoz Posted February 24, 2016 Share Posted February 24, 2016 Picky RAF, picky. And the 36" iPad and it only filled half the line. Link to comment Share on other sites More sharing options...
Tarabuses Posted March 29, 2016 Share Posted March 29, 2016 Is a 4 amp power supply the max that can be used with eLink or can I use a 5 amp supply that I already have? Link to comment Share on other sites More sharing options...
Fishmanoz Posted March 29, 2016 Share Posted March 29, 2016 Welcome to the forums Tb. 4 is the maximum within Hornby specifications. Link to comment Share on other sites More sharing options...
