old_chadders Posted May 10, 2016 Share Posted May 10, 2016 I have a part-used bottle of poly cement and the "needle" applicator is now blocked, presumably with dried adhesive. My plan is to remove the needle from the plastic top and soak it in some sort of solvent, but can anyone advise what is the best? Readily available I have acetone and dichloromethane, Either of which I think should work, but as I don't have anything fine enough to poke down the hole, I don't want to end up with a soggy gel that won't come out! TIA Link to comment Share on other sites More sharing options...
John Symmons Posted May 10, 2016 Share Posted May 10, 2016 Hi Old Chadders.If you can get some telephone wire & strip the insulation the single strand copper inner is just the right size to fit the needle nozzel. Even if you did soak the nozzel you might still need something to work into the tube. If you do manage to unblock it, use the telephone wire to make a keeper ti fit into the nozzel to stop it getting blocked in the future. Just make sure the wire is longer than the nozzel & leave a bent over bit protruding to enable you to remove it when you want to use the cement again. In SA we call this wire "Scooby-Do"Hope this helps.Remember we do this for fun John the Pom Link to comment Share on other sites More sharing options...
RBaker Posted May 10, 2016 Share Posted May 10, 2016 I find removing the needle and holding one end over a flame in my case the gas hobs at an angle melts the glue and it runs out best to do with windows open and hold it with somethign that doesnt get hot or melt Link to comment Share on other sites More sharing options...
richard baker1707820250 Posted May 10, 2016 Share Posted May 10, 2016 I find removing the needle and holding one end over a flame in my case the gas hobs at an angle melts the glue and it runs out best to do with windows open and hold it with somethign that doesnt get hot or melt That is the best method by far. Link to comment Share on other sites More sharing options...
ironsides Posted May 10, 2016 Share Posted May 10, 2016 I use a piece of stainless steel wire with one end bent over that came as rigging for kit, it neatly fits in the tube and under the cap so I dont get blockages anymore, but any solvent or liguid solvent glue that will melt plastic should work fine... liquid poly in a bottle has worked for me in the past.... Link to comment Share on other sites More sharing options...
Matthew72 Posted May 14, 2016 Share Posted May 14, 2016 The flame technique works well. I also will tip my bottle over for anywhere from 15 minutes to an hour and the glue in the bottle will dissolve the glue in the metal tube. Link to comment Share on other sites More sharing options...
Dad Paul B Posted May 16, 2016 Share Posted May 16, 2016 The solvent used in poly cement is Methyl-Ethyl Ketone and difficult to get. Liquid poly is pretty much this with the thicker versions having various amounts of styrene dissolved in them. I generally find that a pin is enough to break the crust after which the fresh cement usually opens up the hole by itself. I tend to use 'precision' which comes unblocked just with the supplied rod. Link to comment Share on other sites More sharing options...
