Go_West Posted December 6, 2016 Author Share Posted December 6, 2016 its funny that that these tools end up in some funny places keep a note if we get phone problems WTD must be the bloke to contact?i can remember as a child a tea towel with a red stripe down it with LNER in white if I had it now might be loads of money.ken Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 6, 2016 Share Posted December 6, 2016 If there was anything around here with anything on it, it would be D broad arrow D, but surely not. And no, I can't answer questions concerning the waging of war. Link to comment Share on other sites More sharing options...
96RAF Posted December 6, 2016 Share Posted December 6, 2016 Whilst we are waiting for Ken's next episode ... ... the oldest purloined thing I ever had was a shovel with HMS Bulldog stamped on the shank of the blade. The handle is now very short, the blade worn well down and its a tad rusty but its still going. Must have been a stokers shovel. Thing is we never had anyone in the Andrew in our family. Link to comment Share on other sites More sharing options...
walkingthedog Posted December 6, 2016 Share Posted December 6, 2016 Perhaps a member of your family picked a fight with a stoker, won, and took his shovel. Or more likely walked away with said shovel embedded in his head 🫨 Link to comment Share on other sites More sharing options...
Go_West Posted December 7, 2016 Author Share Posted December 7, 2016 I did some steam tests just to check how things were going before more test with the body in place and have to say the electronics work fine fitted under the cab floor despite a fault in the drawing a page or to back in the forum which had to be corrected so its hoped that when the body of the engine is fitted that the engine will run fine?There is a small problem with the engines front bogie had some changes made in this area a time back and it appears that at times it derails the main drivers and in the next few pictures I will try to show what I think is happening./media/tinymce_upload/91021b62d65eed2bb46a03707d2d526b.jpgIn this picture the engine is travelling around a curve the picture is taken on the inside of the curve and you can see that there is plenty of clearance between the wheels and the cylinders and frame cut outs./media/tinymce_upload/579ff3d3c1897e1ffc9cc8a9262b8eca.jpgBut when you look on the out side of the curve the front pair are clear of any part of the frames or cylinders but the right hand wheel flange in this picture is hitting the cylinder end covers and frames.To over come this it might be worth moving these wheels just a few thou back away from the cylinders. I should point out that this bogie is a Hornby unit from a Castle class loco I think but its build is better than the fabricated one in the kit and that’s why I prefered it to the kit one/media/tinymce_upload/07796196ed4c0ba1d8c50c8fb92c3484.jpgLooking at the picture above on a straight bit of track all the wheels look OK with the frames and cylinders you might even notice the front and rear drivers have been changed around to see if the engine had any more grip on the rails with the rubber tyres at the back but will check this change out later./media/tinymce_upload/91956475ecccc2b537f4b274fba25f5c.jpgThe pictures here give the make up of the bogie connection to the engine .1 The black arrow is the main fixed fixing point to the engine.2 The white arrows are show the pivot points in the linkage.3 The red arrow is a spring which helps carry the weight of the front of the engine and keep the bogie in contact with the rails./media/tinymce_upload/976f59774fd2c165aa7b52c0252c38a1.jpgThe spring could be made a little weaker to give more flexibility as this to might have an effect on the running but there again the engine has not been tested with the body on and this will add more weight to the overall model. Link to comment Share on other sites More sharing options...
walkingthedog Posted December 7, 2016 Share Posted December 7, 2016 The fault with the trailing wheel fouling the cylinder is fairly common with RTR outside cylinder locos where the drain cocks are is the accessory bag. All is well until you add the drain cocks and suddenly the loco derails on curves. Link to comment Share on other sites More sharing options...
Go_West Posted December 7, 2016 Author Share Posted December 7, 2016 That's very interesting you would think that any manufactured item would have been tested before sales went ahead.i know that when the GWR kings went into service one or two had the front bogies derail at speed due to bad springing and that the inside axle boxes were over heating plus cracks in the frames near the centre fixing point were discovered so much work was carried out to fix these proble. Link to comment Share on other sites More sharing options...
walkingthedog Posted December 7, 2016 Share Posted December 7, 2016 These extra details are left off because some layouts have tight ish curves. Same occurs with steps fouling the bogie. Link to comment Share on other sites More sharing options...
Go_West Posted December 8, 2016 Author Share Posted December 8, 2016 that is always a problem with modeling railways i think its possible to build tight curves which would not have worked on a full size railway. /media/tinymce_upload/29cc848b7666455b5905b1f6dbe48736.jpg /media/tinymce_upload/df2727c95da6359b4365ceea80a4664a.jpgi thought i would put in the GWR problems with there front bogiesIf you look at the pictures here the first picture shows the original design and the last picture shows how it looks now the area that changed is in the springing the first picture shows the leaf spring with its 2 bolts fixed to brackets with very small shock absorbers The next picture shows that the brackets were moved up the frames and coiled springs were added and much larger shock absorbers fitted Link to comment Share on other sites More sharing options...
walkingthedog Posted December 8, 2016 Share Posted December 8, 2016 The Kings bogie was pretty unique. Link to comment Share on other sites More sharing options...
96RAF Posted December 8, 2016 Share Posted December 8, 2016 KenI wouldn't have thought traction tyres would be much advantage on a live steam loco as with all the oil and stuff getting thrown around they must be permanently slippy. The loco is looking real good.Rob Link to comment Share on other sites More sharing options...
Go_West Posted December 8, 2016 Author Share Posted December 8, 2016 Robdid some steam tests after moving the second bogie axle back half a mill and increased the spring tention a little more and the engine ran much better but I think there's a weight problem as unlike the Hornby design the chassis is much lighter and all the weight is way up the front end of the engine pass the first drivers to help balance this out i have added some lead to the back end of the cab so it should run even better I hope with the body on We will see. Link to comment Share on other sites More sharing options...
96RAF Posted December 8, 2016 Share Posted December 8, 2016 Weight where it is needed is obviously the best method Ken, but you could use the tender link as bias. My Hornby B1 would slip all the time as the tender link was lifting the rear drivers a tad; biasing the tender link to apply downwards pressure on the rear drivers may help but it isn't a proper fix though so not really advised. It may work on the straight but over bumps and round corners you could be back to derailing again. More weight in the right place is better. Hopefully the brass body will be enough.Rob Link to comment Share on other sites More sharing options...
Go_West Posted December 8, 2016 Author Share Posted December 8, 2016 Well grand dad looks like we have a runner I wander what he would say if he was here now?/media/tinymce_upload/7d94e40f1bc9b9219a588dee4e25c7cf.jpgThe engine was filled with water and the new idea for filling the oil tank via the smoke box door was a great success with its easy fill system no screws to remove and refit./media/tinymce_upload/6168177227cd2e3195c032a37ec77c45.jpgHalf a dozen steam runs were carried out with the body fitted to the chassis and adjustments made to the front bogie as it still tends to jump the tracks now and again but further investigations are needed to correct this, the main drivers were put back as they were and no noticeable change in traction was noticed The engine was run just on its own to start with and it nipped along with some speed but not enough to fall off on the curves./media/tinymce_upload/3f1eb7a5861b0450bd485518b52e619b.jpgNow with 4 coaches on the engine still performed well these coaches I had repainted to GER standard rolling stock even down to the transfers which I made on the PC and carriage lighting./media/tinymce_upload/d4ad62eb3f869569f167e435281bbf54.jpgThe tender run great with no faults and every steaming the stopping and starting was ok and the problem with the electronics over heating had gone even at the end of some long runs I still had control of the engines speed so the new location under the chassis was a good idea. The magnet for the flashing light had disappeared but was working fine at the start so must look into that small problem. But at least it runs and when I started this build I did not know what was going to happen. Find the paint and order the transfers and what would be a good number for this engine? Link to comment Share on other sites More sharing options...
choralc Posted December 8, 2016 Share Posted December 8, 2016 Brilliant. Link to comment Share on other sites More sharing options...
96RAF Posted December 9, 2016 Share Posted December 9, 2016 Fantastic Keni look forward to,seeing it with its coat on.What was your grandads works number - would that look out of place on the cab.Rob Link to comment Share on other sites More sharing options...
walkingthedog Posted December 9, 2016 Share Posted December 9, 2016 Amazing, I've enjoyed every second of this project. Can't wait for the next one 😆 😆 Link to comment Share on other sites More sharing options...
Go_West Posted December 9, 2016 Author Share Posted December 9, 2016 Things to do1 refit magnet better for flashing light2 get whistle fitted and working3 make back of the boiler fittings inside cab 4 set crew up in the cab5 convert the Hornby tender wheels to have spokesi think that's it unless I think of anything else will work on the front bogie today and if things go right take some video of the engine running round my track as for old George's works number I think it is posssible to track it via old railway records just like Who Do You Think You Are! so could have a search.here is is at work not sure if it's Swindon of Stratford I think it's Swindon as he looks young in this picture he's the one on the right./media/tinymce_upload/996134e4abfa5e9e01a5f094a0984970.JPGbut things are getting busy now as Christmas is approaching so will be a job fitting in time for my new engine just when its coming together OK.Ken Link to comment Share on other sites More sharing options...
96RAF Posted December 9, 2016 Share Posted December 9, 2016 KenHere is an interesting little read for you...http://sas-space.sas.ac.uk/2812/1/Brownlee_-_MA_dissertation_-_2010.pdfRob Link to comment Share on other sites More sharing options...
Go_West Posted December 10, 2016 Author Share Posted December 10, 2016 Hi Robthanks for that have looked at parts but when time permits print it off and read it through funny how they seem to link Swindon and Stratford as grand father was born I think In Swindon he had 2 brothers and 1 sister and I think they all worked in Swindon works his father was in the boiler shop but my grandfather had found out the Stratford paid a penny a day more than Swindon so packed his bags and left for the big smoke to make his fortune. Dad said they say them steets in London are paved in gold and walking to his digs he notice a gold sovereign on the path he went to pick it up but then thought No I'll start tomorrow as I'm a bit tired after the trip down. Link to comment Share on other sites More sharing options...
Go_West Posted December 10, 2016 Author Share Posted December 10, 2016 an up date just to say mods to the front bogie look like it's worked by taking off 10 thou all round and increasing the spring loading and steam tests were great with the coaches attached so I hope to do some video tomorrow so you can see it. Link to comment Share on other sites More sharing options...
Go_West Posted December 12, 2016 Author Share Posted December 12, 2016 Up loaded a new video of the engine with the body on in steam on my track Link to comment Share on other sites More sharing options...
Rog RJ Posted December 12, 2016 Share Posted December 12, 2016 Brilliant! Link to comment Share on other sites More sharing options...
walkingthedog Posted December 12, 2016 Share Posted December 12, 2016 Tremendous, well worth the effort. Link to comment Share on other sites More sharing options...
96RAF Posted December 12, 2016 Share Posted December 12, 2016 Job's a gud'un. Link to comment Share on other sites More sharing options...
