81F Posted November 27, 2011 Share Posted November 27, 2011 I have sucessfully fitted chips to a number of Margate built tender drives (original 28XX, 8F and GWR 4000 gal tender) However, the slow speed control is now worse than when they were DC. I guess ithe problem is with CV settings or maybe the start voltage?can anyone suggest a set of CV values. The Chips are not saphire but the 8 pin type. Link to comment Share on other sites More sharing options...
Gregd99 Posted November 28, 2011 Share Posted November 28, 2011 have you checked the stall current for your locos and decoders?Tender drive makes me think older rather than newer. Older often indicates more current rather than less.when you say poor running is it jerky, does the loco stop... what happens?The answer to your question re Cvs depends on the decoder type.There are CVs to set starting voltage, control back-emf (a possible culprit) and a whole lot more. the 8249 (hornby standard) has limited configuration options. the sapphire has more other decoders have more.a bit more info is needed. Link to comment Share on other sites More sharing options...
Flashbang Posted November 29, 2011 Share Posted November 29, 2011 HiYou cannot adjust CVs for start volts etc with the basic Hornby decoder. You will need to use the Sapphire decoder or obtian another make of decoder that allows CV alterations. Assuming your DCC console allows this. Note: The Select doesn't provide this option other than a few pre set CVs. The Elite does allow full CV alterations when supported by the decoder. Link to comment Share on other sites More sharing options...
Pannier Tank Posted November 29, 2011 Share Posted November 29, 2011 Hi,I have done the same for the old 4-4-0 Counties & Saint and had a similar problem. At initial start up the 3 pole ringfield armature would just flutter back & forth rather than turn, as you increase the power it would launch itself down the track. I got fed up with messing about & put the tender from my 38xx on them as a trial. All worked fine. I then replaced the 3 pole tender drive with the later 5 pole version found in the 38XX heavy freight. They swapped over fine and run nicely.PT Link to comment Share on other sites More sharing options...
trainlover23 Posted November 29, 2011 Share Posted November 29, 2011 81F said:I have sucessfully fitted chips to a number of Margate built tender drives (original 28XX, 8F and GWR 4000 gal tender) However, the slow speed control is now worse than when they were DC. I guess ithe problem is with CV settings or maybe the start voltage?can anyone suggest a set of CV values. The Chips are not saphire but the 8 pin type.Try your local DCC specialist in Kidlington ie Howes of Oxford Link to comment Share on other sites More sharing options...
81F Posted January 27, 2012 Author Share Posted January 27, 2012 Pannier Tank said:Hi,I have done the same for the old 4-4-0 Counties & Saint and had a similar problem. At initial start up the 3 pole ringfield armature would just flutter back & forth rather than turn, as you increase the power it would launch itself down the track. I got fed up with messing about & put the tender from my 38xx on them as a trial. All worked fine. I then replaced the 3 pole tender drive with the later 5 pole version found in the 38XX heavy freight. They swapped over fine and run nicely.PTThis is more or less the same problem. Is this just a case of swapping armatures or the whole drive uniit. My locos are generally late 80s/early 90's. Oddly the King and Saint aren't too bad, it is the 8F (ex county unit) and the 28xx that shoot off.I have to confess I took a more drastic actions with the counties and put the old bodies on new Railroad Chassis!Thanks everyone for the advice - I may try Howes but it's a bit of a trek since they moved - Though not as far as Osbournes! Link to comment Share on other sites More sharing options...
