simontk Posted March 18, 2017 Share Posted March 18, 2017 Is this a piece of computer software, to design and see a running version of your layout ?Like Scarm but with htthe ability to run various engines round the layout ?I know Hornby no longer sell it, but I can still get it on e-bay.Simon. Link to comment Share on other sites More sharing options...
Fishmanoz Posted March 18, 2017 Share Posted March 18, 2017 Track design only Simon, no locos and only Hornby set track, no flexitrack. Stick with SCARM. Link to comment Share on other sites More sharing options...
Rog RJ Posted March 18, 2017 Share Posted March 18, 2017 Hornby Virtual Railway (HVR) and HVR2 was for designing and simulating a layout but was dropped some time ago.Some people seem to have had problems when they tried to build a real layout designed in the program, finding that sometimes tracks wouldn't meet properly. I had a lot of fun with it but never actually built any layouts using it. You may be able to find HVR2 secondhand. Link to comment Share on other sites More sharing options...
westernwill Posted March 18, 2017 Share Posted March 18, 2017 There is an extension to SCARM that simulates running trains. You can use a limited version for free but need to buy the full version. Link to comment Share on other sites More sharing options...
Chrissaf Posted March 18, 2017 Share Posted March 18, 2017 As a follow up to WW's post, I have just installed the free version 'Train Simulator' extension to my existing copy of SCARM. I can report that it worked effortlessly first time. Was easy to install and set up. Its operation is so straight forward that I had no need whatsoever to resort to reading instructions. The train being simulated works in both the 2D and 3D track view. Any points in your SCARM track design, now have position indicators and are clickable to change the route the simulated train takes. The limitation of the 'free version' is only one choice of a single Diesel loco and a few passenger coaches..Note: that to install the Simulator, you have to do it from within the SCARM application itself, using the 'Extensions' tab on the SCARM navigation bar. This takes you to a web page, where you have to click TWO separate links to install, firstly the Simulator throttle and secondly the 'free version' train pack as described above. The installer uses the browser to install the files and may possibly be browser specific. I am using Firefox 52.0 for Windows..PS - Once the extension files have been installed. Go back to the SCARM 'Extensions' tab and you will find the Simulator 'Launch' menu option is now present..Note; I was running the very latest version of SCARM before I installed the extension. If your version of SCARM is earlier and does not have the 'Extensions' tab showing, then you will have to upgrade SCARM first. Link to comment Share on other sites More sharing options...
96RAF Posted March 18, 2017 Share Posted March 18, 2017 Just installed the SCARM extensions Chris and as you say instructions are optional and it works a treat despite the incompatible track warning - no faults at all. Great fun testing the play value of a layout and seeing where operational issues could be before laying a single piece of real track.Rob Link to comment Share on other sites More sharing options...
Chrissaf Posted March 18, 2017 Share Posted March 18, 2017 ....despite the incompatible track warning - no faults at all..I didn't see that warning on my SCARM track layout.... Link to comment Share on other sites More sharing options...
96RAF Posted March 18, 2017 Share Posted March 18, 2017 It was referring to some I built in a much older revision. Link to comment Share on other sites More sharing options...
