81F Posted May 29, 2017 Share Posted May 29, 2017 Can someone suggest a DCC chip for the Electrotren (H0 1:87) Steam locomotive “L.Aguirre” 0221? I have tried both Bachmann straight and rght angle chips as well as a small gaugemaster one but cannot get the body back on. The Bachmann right angle one fitted but did not work until I turned it round and ten I couldn't get the body back on. I notice that there seems to be a recess behind the back plate so wonder if a chip would din in there but I would need a six pin with a plug and leads. Link to comment Share on other sites More sharing options...
Howbi Posted May 29, 2017 Share Posted May 29, 2017 This might fit...........HB/media/tinymce_upload/a43307304fd22c92067fcce66d88f61d.jpgOn second thoughts, it might not if yours is a six pin socket....... 🤔.........HB Link to comment Share on other sites More sharing options...
Howbi Posted May 29, 2017 Share Posted May 29, 2017 Look at this, might be cheapest option as you already have the 6 pin decoder, it's just the harness.......from DCC Concepts..........HB/media/tinymce_upload/18e9c4f9ced9544ee72b58ff7b29ebf1.jpg Link to comment Share on other sites More sharing options...
Michael_A Posted June 7, 2017 Share Posted June 7, 2017 Have you looked at the Bachmann 36-568? Link to comment Share on other sites More sharing options...
81F Posted June 28, 2017 Author Share Posted June 28, 2017 Have you looked at the Bachmann 36-568?Yep! it was the first one I tries. The trouble is that it is too long with the top fouling the underside of the smoke box. The extension wires were a good idea but I needed six pin to six pin not eitht to six. And even with 6 to 6 that combined length made it too big to fit behind the fire box. However, I've now solved the problem with a very expensive ESU six pin chip which has a plug and wire rather than being direct fit. It was still difficult getting the body back on but the loco is now back together. Many thanks for the suggestions Link to comment Share on other sites More sharing options...
