stuh Posted December 27, 2011 Share Posted December 27, 2011 Hi got a new Jame sent from the UK but we are not able to get anything working. Thomas works fine on the track. Where do I start to find the fault. Link to comment Share on other sites More sharing options...
Disco Posted December 27, 2011 Share Posted December 27, 2011 Are you using a DCC layout with James, who is an Anologue Loco perhap?I'm having the same problem with a DCC converted Edward if you can shed some light on that one too! lol Link to comment Share on other sites More sharing options...
stuh Posted December 27, 2011 Author Share Posted December 27, 2011 Hi using DC Thomas track set bought at the same time. I don't think James is FCC but how would I tell as it came in white box and not a set. Link to comment Share on other sites More sharing options...
Disco Posted December 27, 2011 Share Posted December 27, 2011 stuh said:Hi using DC Thomas track set bought at the same time. I don't think James is FCC but how would I tell as it came in white box and not a set.ah, well no.. both will be Analogue (DC).. so not sure why it isn't working mate sorry Link to comment Share on other sites More sharing options...
Moomintroll Posted December 28, 2011 Share Posted December 28, 2011 Given Thomas works and James dosen't, it's safe to say problem is James. my guess is one of three issues:1: Short circuit, very easy to do with these engines, try running the tendor alone with no james. you may need to move it a little on the tracks. Most likely place for a short is coupling, make sure these are not bent into shorting.2: Bad circuit, between enging and tendor. I don't get why Hornby paint the coupler pin with black paint which kills the cicuit! try scraping it where the contacts are (ones which hug the pin ´not ones which are compressed by top plate.3: Engine broken. If new unlikely, if 2nd hand posible also if someone has thrown a set together and used the wrong tendor (with correct top) the connectors could be wired the wrong way and wll cause a short (try running Gordon with Henrys tendor!).1&2 should be easy things to resolve if they don't fix your problem and no returns policy, send it to s service repare center. Link to comment Share on other sites More sharing options...
The son of Triangman Posted December 28, 2011 Share Posted December 28, 2011 If the loco is under warranty you need to contact the shop or Hornby Customer Service, customer service are very good. DONT mess with the loco yourself if it's under warranty. Link to comment Share on other sites More sharing options...
stuh Posted December 29, 2011 Author Share Posted December 29, 2011 Hi have tried the tender on its own with no joy. We get a voltage that seems OK from what I know. The train was a present for my sonfrom the UK to Australia so not keen to send back to the UK. Unit was purchased new. Link to comment Share on other sites More sharing options...
Moomintroll Posted December 30, 2011 Share Posted December 30, 2011 If you can't get the tendor to even power up then sounds like an issue with the motor. Could happen easily with a heavy handed post man... I suspect to send it back of forth to Austraia is going to cost about 15-20 pounds alone. If they have the reciept Hornby will sort this out for you in the UK, if not, your first loss is your best loss as they say... click on stockists on botton left of this screen and find a repair center near you. I suspect you'r looking at 30 pounds or so. The tendor drive are the easiest to fix but if your not handy with a soldering iron...Have you taken the top off the tendor to check for a broken/loose wire^ Link to comment Share on other sites More sharing options...
stuh Posted January 2, 2012 Author Share Posted January 2, 2012 Hi,Yep cover off checked all connections and voltages etc, seems fine. So we dropped it into a hornby store for them to have a look at and replace the engine if required.Thanks Link to comment Share on other sites More sharing options...
trainlover23 Posted January 28, 2012 Share Posted January 28, 2012 If you purchased it from the UK you will have to send it back to the UK Link to comment Share on other sites More sharing options...
