DEREK123 Posted September 21, 2017 Share Posted September 21, 2017 I am posting this as it may be an answer or maybe just help to many who have had these stuttering problems after fitting DCC A4 sound chips to a Tornado ....... like me !!I TRIED EVERYTHING !! ... all suggestions in the various posts/threads.Unknowingly I had squashed/bent a valve gear rod ... you would not have noticed it !! .. the alignment was so slight that I could hardly see the catch . I could not believe that I had done it. I have now straightenned it , wriggled the cylinder block ( just to ensure that it was not damaged too !! ) and solved the stop start stuttering !! .... I had tried all the CV tweeks to no avail like so many here ... one thing that I noticed was that before I sorted it sometimes ( to get it moving ) I needed to move the chassis from sde to side on the track as I thought that I was not getting a good connection to the wheels/rails .... that got it moving but it still stuttered !!If you have the stuttering symptoms with your loco I recommend you have a really close look at the rods on your loco too !Good luckDerek Link to comment Share on other sites More sharing options...
96RAF Posted September 22, 2017 Share Posted September 22, 2017 Thanks for posting the admission DerekMany would have gone red faced and kept their head down.Rob Link to comment Share on other sites More sharing options...
