charliebella Posted September 22, 2017 Share Posted September 22, 2017 How do you set volumes engines fitted with TTS sound Link to comment Share on other sites More sharing options...
Chrissaf Posted September 22, 2017 Share Posted September 22, 2017 It depends upon which DCC controller you have......what one have you got?.Note that you can't adjust volumes using the Hornby Select controller. Link to comment Share on other sites More sharing options...
Howbi Posted September 22, 2017 Share Posted September 22, 2017 CV178 controls the volume of all the sounds together, the range is 1 to 8 where 8 is loudest..........if it is just the chuff you wish to reduce then the CV is 161, range 1 to 8........if you also wish to reduce the background steam hiss, change CV160 again range 1 to 8.......HB Link to comment Share on other sites More sharing options...
96RAF Posted September 23, 2017 Share Posted September 23, 2017 Overall volume level is CV182 for TTS diesels. Link to comment Share on other sites More sharing options...
Phil_Spiegel. Posted September 25, 2017 Share Posted September 25, 2017 Unfortunately Hornby does not seem to have standardised on a common set of CVs to adjust sound levels (or some functions) between the various models.... a crib sheet is needed for each loco. Link to comment Share on other sites More sharing options...
Howbi Posted September 25, 2017 Share Posted September 25, 2017 There is a user manual with each decoder listing all the sound functions and configurable CVs..........obviously, the instructions for Diesel TTS are slightly different from Steam TTS. Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 25, 2017 Share Posted September 25, 2017 In short, a crib sheet is provided with each loco. Link to comment Share on other sites More sharing options...
