ron 47 Posted September 25, 2017 Share Posted September 25, 2017 Hi all just whant to know if you can put a stay a live in a tts sound loco and how to fit itthank Ron Link to comment Share on other sites More sharing options...
96RAF Posted September 25, 2017 Share Posted September 25, 2017 In theory - yes you can but you need to know where on the decoder to make your connections and on a TTS decoder those points may be hidden by the piggy-back sound board.There is a picture here of typically where to connect to an decoder to give you an idea of what it involves......as part of this discussion.Rob Link to comment Share on other sites More sharing options...
ron 47 Posted September 25, 2017 Author Share Posted September 25, 2017 Thank You RAF69looking to much to doThank you Ron. Link to comment Share on other sites More sharing options...
Howbi Posted September 25, 2017 Share Posted September 25, 2017 I can confirm that the Bridge Rectifier diodes have the same arrangement on the TTS board as those shown in Rob's "Picture here" above..........I got a DC reading of 16.5 volts.......the solder pads are just 1mm square so a very delicate job to solder wires to.........(pity we can't upload a photo to illustrate).........HB Link to comment Share on other sites More sharing options...
96RAF Posted September 25, 2017 Share Posted September 25, 2017 @HBM1mm square is huge compared to the size 0603 smd leds I have been soldering into my Class 56 body.And those are easy compared to the 1.5mmm square 8-legged smd dual H-bridge devices I have so far failed to sucessfully solder into my Elite.Rob Link to comment Share on other sites More sharing options...
Howbi Posted September 25, 2017 Share Posted September 25, 2017 Rob.......you need those magnifying goggles with built in headlights....... 😎.......HB Link to comment Share on other sites More sharing options...
