olly Posted September 27, 2017 Share Posted September 27, 2017 Hi everyone I am currently trying to fit a TTS decoder in the high detail class 31 The supplied speaker wouldn't fit without removing the fan mechanism so I thought about using a sugar cube speaker. before changing the speakers I tested everything to make sure it was okay.The locomotive was a very good runner before fitting the decoder but was a very poor runner with the decoder fitted so I changed CV 150 to value 1 and that instantly improved the running. a friend of mine had also purchased the same decoder to fit into his 31 and had the same problems with the running of the locomotive he contacted Hornby and they told him to change CV 151 to value 255 and CV 152 to value 1 either of these two methods will make the locomotive run properly with the TTS decoder fitted. it basically changes the motor control algorithm. it doesn't seem to matter which of the two methods mentioned above you use they both give the same result there is no difference in performance that I have found.concerning the sound being very quiet I have the volume turned up to full and it's still quite quietusually I find with the TTS decoders I have to turn the sound down a little or at least leave it at default. I have fitted sugar cube type speakers to other TTS decoders and have found that as well as improving the sound quality they also give a better volume usually I have to turn them down to volume level 3.but this one is very quiet totally different to any of the other TTS sound decoders I've hadhas anyone else fitted a high detail 31 with the TTS decoder? Have you managed to get the sound to a reasonable level and what speaker have you fitted?I hope when the class 60 comes out this has more volume Link to comment Share on other sites More sharing options...
2e0dtoeric Posted September 27, 2017 Share Posted September 27, 2017 Three possibilities -1) duff speaker2) wrong impedence speaker (ie a 16 ohm one instead of a 4 ohm one)3) duff audio amp on the decoder.Try putting the original speaker back on the decoder, and try it, even though it doesn't fit the chassis, that will prove the area to look for the fault. If it is very quiet too, duff amp, if it blows your ears off, duff or wrong speaker!Look on the back of the speaker magnet - there should be a number, and an omega sign. (my keyboard doesn't have one, but it's the upside down U with two hooks on it). Link to comment Share on other sites More sharing options...
morairamike Posted September 27, 2017 Share Posted September 27, 2017 TTS speakers are 8 ohms. is it sealed well with its enclosure. I fitted a sugarcube today to a Castle class and it was quiet, put in another from a different supplier and it's loud, had to turn the cv 178 down to 3 (max is 8) Link to comment Share on other sites More sharing options...
olly Posted September 27, 2017 Author Share Posted September 27, 2017 Three possibilities -1) duff speaker2) wrong impedence speaker (ie a 16 ohm one instead of a 4 ohm one)3) duff audio amp on the decoder.Try putting the original speaker back on the decoder, and try it, even though it doesn't fit the chassis, that will prove the area to look for the fault. If it is very quiet too, duff amp, if it blows your ears off, duff or wrong speaker!Look on the back of the speaker magnet - there should be a number, and an omega sign. (my keyboard doesn't have one, but it's the upside down U with two hooks on it).The sugar cube is an 8 ohm 1 watt I tried the Hornby speaker first when I did the ini test run and the sound was very quiet I thought the sugar cube would improve things but it hasn't the hornby speaker has no markings on the back The paper work says it's a 8 ohm 1 watt a 4 ohm speaker would blow the decoder TTS decodes can only use 8 ohm,smy friends decoder was also very quiet he had tried two speakers and it was still quiet he has sent it back to the shop Link to comment Share on other sites More sharing options...
2e0dtoeric Posted September 27, 2017 Share Posted September 27, 2017 Faulty batch of decoders, then? Link to comment Share on other sites More sharing options...
olly Posted September 27, 2017 Author Share Posted September 27, 2017 Sounds like me and my friend have been unlucky with a duff amp on the decoders I will try another speaker tomorrow just in case both the hornby fitted one and the sugar cube are both faulty Morairamike what was the speaker you used? yes when i have fitted better speakers to a TTS I have needed to turn the volume down. I have an a4 with a zimo speaker and that's set at volume level three Link to comment Share on other sites More sharing options...
olly Posted September 27, 2017 Author Share Posted September 27, 2017 Faulty batch of decoders, then?Could be that's why I asked on here if anyone had the same problem I may see what hornby have to say about this Link to comment Share on other sites More sharing options...
morairamike Posted September 28, 2017 Share Posted September 28, 2017 Olly85.The loud speaker is a LSPECKIG ECKIG MINI OBLONG SPEAKER 8 ohms from Digitrains. They come with a separate enclosure. Link to comment Share on other sites More sharing options...
Britannia Builder Posted September 28, 2017 Share Posted September 28, 2017 I think the latest TTS decoders may be a bit quieter than earlier ones. On my TTS Duke of Gloucester bought 18 months ago I had to turn the volume levels right down to 1, but on the A1 TTS decoder that I fitted recently to my Peppercorn A1 I left them at the default 4, and likewise on my recently acquired Railroad Class 31 with factory-fitted TTS I left most of the volumes at 4 and turned the horns up to 6 - all with the standard Hornby-supplied speakers. Interesting comment from Hornby about leaving cv150 at 0 and changing 151 to 255 and 152 to 1. I've always just changed cv150 to 1, but I might give this a try. Regards, John Link to comment Share on other sites More sharing options...
olly Posted September 28, 2017 Author Share Posted September 28, 2017 I think the latest TTS decoders may be a bit quieter than earlier ones. On my TTS Duke of Gloucester bought 18 months ago I had to turn the volume levels right down to 1, but on the A1 TTS decoder that I fitted recently to my Peppercorn A1 I left them at the default 4, and likewise on my recently acquired Railroad Class 31 with factory-fitted TTS I left most of the volumes at 4 and turned the horns up to 6 - all with the standard Hornby-supplied speakers. Interesting comment from Hornby about leaving cv150 at 0 and changing 151 to 255 and 152 to 1. I've always just changed cv150 to 1, but I might give this a try. Regards, John I have also just changed cv 150 to 1 to improve the running in the past. both ways work the same it's interesting what you say about the new decoders being quieter than earlier ones. I will see what the volume is like on the next one I buy I have phoned Hornby this morning and have returned the 31 decoder to them to look at Link to comment Share on other sites More sharing options...
olly Posted October 5, 2017 Author Share Posted October 5, 2017 Got the decoder back from hornby yesterday they said that no fault was found and the sound is as programmed so not sure what to do next it wont work with a zimo sugar cube which has the same ratings as the supplied speaker maybe I will try different speakers or would it be possible to fit two speakers not sure if the decoder will take two speakers ? Link to comment Share on other sites More sharing options...
Britannia Builder Posted October 5, 2017 Share Posted October 5, 2017 I've now turned all the horn sounds on my Railroad TTS Class 31 up to volume 8, with the engine sounds left at 4. I also turned the guard's whistle (F23) up to 8 but that was really loud and I turned it down to 6. Is the guard's whistle louder than other sounds on your class 31? I wonder if Hornby have changed the output power of the TTS hardware, or simply recorded the sounds at a lower level than usual, in response to previous comments about TTS sounds being too loud even on level 1? I have a Railroad class 47 which I retrofitted with a TTS decoder 6 months ago (bought from Rails who split them out from TTS locos) and I find the engine sounds somewhat on the loud side even at volume level 1, so to be honest I prefer the new TTS decoder volumes. I guess it depends on the size of your room etc. I imagine that two 8ohm speakers in parallel would be equivalent to one 4ohm one, so might damage the TTS decoder. Regards, John Link to comment Share on other sites More sharing options...
olly Posted October 5, 2017 Author Share Posted October 5, 2017 I've now turned all the horn sounds on my Railroad TTS Class 31 up to volume 8, with the engine sounds left at 4. I also turned the guard's whistle (F23) up to 8 but that was really loud and I turned it down to 6. Is the guard's whistle louder than other sounds on your class 31? I wonder if Hornby have changed the output power of the TTS hardware, or simply recorded the sounds at a lower level than usual, in response to previous comments about TTS sounds being too loud even on level 1? I have a Railroad class 47 which I retrofitted with a TTS decoder 6 months ago (bought from Rails who split them out from TTS locos) and I find the engine sounds somewhat on the loud side even at volume level 1, so to be honest I prefer the new TTS decoder volumes. I guess it depends on the size of your room etc. I imagine that two 8ohm speakers in parallel would be equivalent to one 4ohm one, so might damage the TTS decoder. Regards, John think you might be right about the sound volumes being lower on the new decoders I preferred the old TTS myself at least the volume could be turned down if it was to loud for you that's what I wanted to check when I was trying to work out I got 8ohm or 16 ohm depending on how they were wired I've just had a look at your website Britannia builder that's a very impressive loco . Maybe my numbers will come up on the euro millions the I could have something like that and fit all my 00 locos with Zimo or Esu sound Link to comment Share on other sites More sharing options...
WilliamDavid Posted October 5, 2017 Share Posted October 5, 2017 I don't observe any difference in sound levels of the ready fitted decoders with the new A1/3, A4 and Tornado decoders. Have noticed the fitted Class 31 is a bit quieter, though. Link to comment Share on other sites More sharing options...
olly Posted October 15, 2017 Author Share Posted October 15, 2017 I have finally got my class 31 to work properly with the TTS decoder and have found a speaker the fitts in the loco that gives a decent volume and sound quality the speaker is a zimo 3D optimised speaker 8 Ohm 1 watt L26 x W20 x H 8mm I have the volume set to value 6 this seems about right to me the only issue I am having now is the locomotive jumps forward about 1mm when the sound has finished starting up has anyone else had this issue and have you managed to fix it? Link to comment Share on other sites More sharing options...
Sandbar Posted May 28, 2018 Share Posted May 28, 2018 I fitted this decoder to my Class 08 diesel as I wanted to try out the motor sound. The speaker had to be remove from the housing and stuck to the roof of the loco, but volume is soft. I am not interested in the horn sounds but would like a proper sound for the class 08. I have a master & slave or cow & calf unit depending how you understand it. Cheers from AndrewSandbar & Mudcrab Railway Link to comment Share on other sites More sharing options...
96RAF Posted May 29, 2018 Share Posted May 29, 2018 My 31 sound is OK with a standard speaker. The 08 has a smaller oblong speaker to fit in the radiator area, also adequate volume.Rob Link to comment Share on other sites More sharing options...
olly Posted May 29, 2018 Author Share Posted May 29, 2018 I fitted this decoder to my Class 08 diesel as I wanted to try out the motor sound. The speaker had to be remove from the housing and stuck to the roof of the loco, but volume is soft. I am not interested in the horn sounds but would like a proper sound for the class 08. I have a master & slave or cow & calf unit depending how you understand it. Cheers from AndrewSandbar & Mudcrab RailwaySandbar you say removed the housing and stuck the speaker to the roof. Removing the speaker enclosure will affect the sound volume and quality. Try a sugar cube type speaker Link to comment Share on other sites More sharing options...
