258rp Posted October 26, 2017 Share Posted October 26, 2017 Hi. lv been given a DCC Ready Scotsman, but l dont know it's ID number, Iv tryed the obvious 0003, then lv tryed 0001 up to 0010. but l dont want to keep guessing because l might do more harm than good. So is there away to detect an ID adress..........?lm on w10, and RailMaster elink. Link to comment Share on other sites More sharing options...
96RAF Posted October 26, 2017 Share Posted October 26, 2017 Just use RM to read the decoder on a length of programming track, then if its not the address you want write a new address or just write your preferred address anyway, although it is advisable for any 'unknown' decoder to write value 8 to CV8 to put it back to factory default standard, then you have a known starting point for each and every CV value.Rob Link to comment Share on other sites More sharing options...
RDS Posted October 26, 2017 Share Posted October 26, 2017 If it is just DCC ready (rather than DCC fitted), it will not have an ID. Link to comment Share on other sites More sharing options...
RDS Posted October 26, 2017 Share Posted October 26, 2017 Hi 258rpI have just been looking at your previous posts and it seems that the DCC ready or DCC fitted situation was mentioned back in September.Is this the same Loco that you were referring to in those posts? Link to comment Share on other sites More sharing options...
96RAF Posted October 26, 2017 Share Posted October 26, 2017 I missed the DCC Ready bit (again).As RDS says it needs a decoder fitting first.Rob Link to comment Share on other sites More sharing options...
