Forum-1211528 Posted November 2, 2017 Share Posted November 2, 2017 Trix TTR was a totally incompatable model railway system thats incompatable with anything really modern so can you DCC TTR locos or is that impossable? Link to comment Share on other sites More sharing options...
96RAF Posted November 2, 2017 Share Posted November 2, 2017 Nothing is impossible Colin but is it necessary. Link to comment Share on other sites More sharing options...
Phil_Spiegel. Posted November 7, 2017 Share Posted November 7, 2017 This partly depends on WHICH PERIOD of Trix Twin you are concerned with: There was ac, and then, there was DC.DC Trix Twin locos included their 3.8mm scale Westerns and other UK production: They had insulated axles, just like a standard 2-rail model, but they ALSO had a central shoe pickup - so power collection was from centre and ONE side - depending on which way the loco was facing. This allowed 2 trains (hence Trix Twin) to be independantly controlled (in analogue, with 2 controllers) on a single length of track! The models convert to standard 2-rail simply by removing the central pickup, and replacing it with pickup-contacts to the insulated set of wheels. From that point, conversion to 2-rail NMRA 'dcc' is fairly standard - as long as the decoder is chosen to have sufficient current for the elderly / less efficient motors of those days.At least one continental manufactuer (ESU) has sensibly adopted the same construction approach to make their models compatible with both the 3 rail and 2 rail markets ! - with the dealer only having to stock a single version !Effectively the model is switched between 3-rail or 2-rail mode by removing the central shoe. No electrical conversion is necessary because the 'ac'/3 rail compatibility is for DIGITAL 3-rail ie Mfx - and many continental makes of decoder are already multi-protocol including the Marklin protocols, as this is a large proportion of the Continental market (at least in Germany and Sweden) So, by selling a top range model with sound and digital control already onboard, the dealer also has the benefit of only needing 1/3 the stock !! (not analogue 2 rail, NMRA 2rail dcc and 3-rail Mfx/Motorola )(In the past, there have also been different 'wheel standards' used - particularly in flange depth. Trix EXPRESS models have quite coarse wheels - and will bump anlong on Peco Code 75 track). Trix Twin were finer, as I recall.The OLD TRIX TWIN AC models also probably had metal bodied locos - and metal bodied locos present another possible problem when converting to Digital ( ie multiple occupancy of a piece of always-live track ) FIRST task woud be to replace any METAL COUPLING with an insulated one, and 2nd task to try and insulate the BODY from either rail - otherwise if 2 locos touched, it might be a short circuit. Notice how UK models rapidly changed to plastic couplers when Zero-1 was introduced !! Link to comment Share on other sites More sharing options...
