ConfusedRobotCat Posted November 6, 2017 Share Posted November 6, 2017 What size traction tyres does Thomas use?4F 0-4-0 Fowler traction tyres fit? Only the traction tyres on mine have worn out. Link to comment Share on other sites More sharing options...
walkingthedog Posted November 6, 2017 Share Posted November 6, 2017 If a loco doesn't have grooves it doesn't have traction tyres. That is normal. Not everything has tyres thank heavens. Link to comment Share on other sites More sharing options...
ConfusedRobotCat Posted November 8, 2017 Author Share Posted November 8, 2017 My Thomas is pretty old. It definitey does have traction tyres, but they're cracked and worn and could do with replacing.On the topic of parts, which of Hornby's spare buffers would fit him? The dang thing has been in storage so long I have no idea how it lost a buffer but it went and did. Link to comment Share on other sites More sharing options...
ronp849 Posted November 19, 2017 Share Posted November 19, 2017 I have replaced several damaged/worn/missing traction tyres with narrow slivers of heat shrink tubing.Two layers per wheel were needed to produce the required thickness.The traction was not quite as good as the genuine tyre but since I did not need to pull 15+ carriages, it was good enough for me. (I have used this for both oo and n gauges). Ron Link to comment Share on other sites More sharing options...
olly Posted November 24, 2017 Share Posted November 24, 2017 These are the correct tyres for Thomas http://www.petersspares.com/hornby-x8101-l5716-l6241-large-060-traction-tyres-pk10.irThe part number is x8101 the 4f are a different size so won’t fit . Heat shrink won’t have the grip of the proper Hornby tyres hope this helps you olly Link to comment Share on other sites More sharing options...
olly Posted November 24, 2017 Share Posted November 24, 2017 With toby clean the wheels with Isopropyl alcohol so there’s no oil or grease on them Link to comment Share on other sites More sharing options...
