jolly john Posted November 27, 2017 Share Posted November 27, 2017 Since i installed the 1.4 firmware to my hornby elite several times my laypot goes dead ,the screen on my controller still is lit up & showing loco address but track is dead .If you turn power off then on every think works fine .Any ideas ?. Link to comment Share on other sites More sharing options...
96RAF Posted November 27, 2017 Share Posted November 27, 2017 Welcome John It sounds like a dodgy connection to me. Check that the link wires are secure at the Elite terminals and at the track clip, also that the track clip is firmly and coorrectly attached if of the slide in type rather than the better push button connection type. If you have some spare wire it may be worth substituting for the existing wire in case it has a broken wire inside the insulation which can happen..If it were a direct short the Elite would show ERROR on screen..It may be that the controller is self protecting because there is too much load on the track, e.g. too many locos and also running auxilliary powered accessories like lights, signals, etc. If self ptrotecting I would expect the screen to go blank then when things have recovered for it to reboot, but never having overloaded mine (not enough locos) I can't say for sure, although the manual says it just shows ERROR. You say you have updated to v1.4, did you mean v1.44 which is the latest firmware state and offers several benefits over v1.4. Rob Link to comment Share on other sites More sharing options...
jolly john Posted November 28, 2017 Author Share Posted November 28, 2017 Thanks for your replies you were right i did install v1.44 . but i dont run any accessorizes and only run two loco"s at one time. Thanks again. Link to comment Share on other sites More sharing options...
96RAF Posted November 28, 2017 Share Posted November 28, 2017 Do you have points and if so have you fitted point clips.Does your track go completely dead or just a part of it. If part of it is it when you change points or go from loop to loop..Rob Link to comment Share on other sites More sharing options...
RDS Posted November 28, 2017 Share Posted November 28, 2017 @jolly johnWelcome to the Forum.Could I suggest that you just connect your Elite to a length of track (no points) away from your main layout and see whether everything operates correctly. Then add one Loco at a time to the track and check what happens at each stage, then report back here with the results. Link to comment Share on other sites More sharing options...
jolly john Posted November 29, 2017 Author Share Posted November 29, 2017 i do have point clips nd all of the track goes dead, it was working fine untill i installed the updated firmware v1.44 . Link to comment Share on other sites More sharing options...
RDS Posted November 29, 2017 Share Posted November 29, 2017 But what happens with a simple track, no points. Link to comment Share on other sites More sharing options...
Fishmanoz Posted November 29, 2017 Share Posted November 29, 2017 Sounds to me like contact HCC and return for repair or warranty if less than 6 months old. I can’t imagine any way that the firmware upgrade has caused this fault. Link to comment Share on other sites More sharing options...
6667s Posted December 10, 2017 Share Posted December 10, 2017 Have you tried resetting the Elite in the menu, Link to comment Share on other sites More sharing options...
96RAF Posted December 10, 2017 Share Posted December 10, 2017 And if a unit reset doesnt help then I would suggest downloading the firmware update again and reloading v1.44 just in case it was a dodgy download. Then if no improvement flag it back to HCC for fettling under warranty.Rob Link to comment Share on other sites More sharing options...
2e0dtoeric Posted December 10, 2017 Share Posted December 10, 2017 and only run two loco"s at one time - - - but how many are on the track? With DCC, ALL loco's are live and drawing power, even if they aren't moving. Only a few milliamps each, if the lights are off, but it all adds upThe Elite has a 4 amp psu. 3 amps is 4000 milliamps. A running loco takes about 500 milliamps, so two locos are drawing an amp. The controller itself uses some, so you have about 2000 milli's left for everything else. Link to comment Share on other sites More sharing options...
jolly john Posted December 13, 2017 Author Share Posted December 13, 2017 It seems to do it when something trips the controller out I reset it then I find all the track is dead .I switch the power off then back on then all is good. Link to comment Share on other sites More sharing options...
jolly john Posted December 13, 2017 Author Share Posted December 13, 2017 Have you tried resetting the Elite in the menu, No I will try it thanks. Link to comment Share on other sites More sharing options...
