Octocon Posted December 23, 2017 Share Posted December 23, 2017 Good AfternoonJust wondering if anyone still has a D4093 08 shunter form the mixed goods set I have just acquired one but have been unable to read the dcc controller on the e-link system but other trains i have are ok, upon closer inspection I believe the DCC unit has been removed to allow the train to run on analogue, anyone have a picture of the innardswith dcc fitted?Sorry just for question new to the hobby and to dcc control regards Octo Link to comment Share on other sites More sharing options...
2e0dtoeric Posted December 23, 2017 Share Posted December 23, 2017 Sorry, don't have a blanking board to hand, but if you look at the board that is fitted, if a blank - it will have almost NO components on it, just a few link bridges between pins. A decoder board will be crammed with tiny components. Link to comment Share on other sites More sharing options...
jane1707819582 Posted December 23, 2017 Share Posted December 23, 2017 Hi pop the body off the loco ,on one side the decoder should be visible ,from memory it is a 4 pin Link to comment Share on other sites More sharing options...
96RAF Posted December 23, 2017 Share Posted December 23, 2017 Have a look at service sheet 278.The little thing plugging into the socket is a blank. If it has a bunch of wires going to a more complex thing like this then its a decoder.https://www.hornby.com/uk-en/digital-locomotive-decoder-v1-3-nmra-compliant.html Rob Link to comment Share on other sites More sharing options...
Howbi Posted December 23, 2017 Share Posted December 23, 2017 As Jane2 said these locos are fitted with the Hornby X9659 4-pin decoder.......this has a harness with a 4 pin socket........if the plug is removed then the motor would be hard wired to the pick-up leads.......HB/media/tinymce_upload/f233b38b589fa520a5cc25cfe6cc961e.JPG Link to comment Share on other sites More sharing options...
Chrissaf Posted December 24, 2017 Share Posted December 24, 2017 And here is a picture of the Hornby X9659 4 pin DCC decoder (where it can be plugged into a corresponding connector on the loco as opposed to hard wired). Be aware that locos with fitted decoders will by default (unless changed by editing a CV) run on Analogue DC as well. So the only way to be truly sure if one is fitted is to remove the body and look for it..https://www.hornby.com/uk-en/4-pin-decoder.html Link to comment Share on other sites More sharing options...
Octocon Posted December 26, 2017 Author Share Posted December 26, 2017 Thank you for the replies It's how I thought decoder has been removed.Guess it's going back with a lesson learnt. Link to comment Share on other sites More sharing options...
