Stegs1969 Posted January 9, 2018 Share Posted January 9, 2018 Hello! I was given a Scalextric Arc Air Race Day Jaguar v McLaren set for Christmas and having played it a bit it's clear that one of the cars (the McLaren) is significantly 'better' than the other; it can go much faster without leaving the track.I know the McLaren would be better than the Jaguar in real life, but wouldn't have thought that would make a difference and it means that racing the two cars isn't much fun as it's always the same one that wins, whichever track, controller or 'driver'. We've also tried it on different track layouts, including a track without tight turns, and it's still the same.Is this normal? Is there anything I can do about it?Any advice at all gratefully received.Thanks,Steve. Link to comment Share on other sites More sharing options...
Andy P. Posted January 9, 2018 Share Posted January 9, 2018 Some Jaguar fans would ask you step outside! :-)Joking aside: usually if the magnet gets dislodge or sits higher and it will mean the car has less downforce.Also check that the wheels are spinning freely and maybe give them a small drip of oil.Maybe the McLaren's braids are not in as good of condition?Follow these instructions:https://www.scalextric.com/uk-en/five-top-tuning-tip-for-christmasFinally, if none of this works, since you have ARC AIR use the APP to reduce the power of the McLaren to get them closer in performance. To do that you have to go to the driver set up before starting a race. Link to comment Share on other sites More sharing options...
Stegs1969 Posted January 9, 2018 Author Share Posted January 9, 2018 Thanks Andy. I'll try that. I'm not really a car person, so McLaren still sounds more impressive to me!!!Of course, nothing beats a Vauxhall but they didn't do a set with an Insignia as one of the cars... Link to comment Share on other sites More sharing options...
Andy P. Posted January 9, 2018 Share Posted January 9, 2018 Hey.. I used to drive Wartburg (called Knight) so should I be talking?! 😎 Link to comment Share on other sites More sharing options...
Twigman Posted January 9, 2018 Share Posted January 9, 2018 Hey.. I used to drive Wartburg (called Knight) so should I be talking?! 😎 You'd still thrash a Moskvitch any day of the week Link to comment Share on other sites More sharing options...
Andy P. Posted January 10, 2018 Share Posted January 10, 2018 A race between a slug and a snail... Link to comment Share on other sites More sharing options...
null_null981707818761 Posted January 23, 2018 Share Posted January 23, 2018 First thing I do is to true the tires. I've noticed on some cars less than half the tire is in contact with the track. I have about 75 cars all types all scalextric. I have had the same thing happen cars you think should handle better than others don't I have found there is usually a reason tires not true body too tight or not fitting properly etc. also keep them oiled axle ,motor bushings. Link to comment Share on other sites More sharing options...
