thirdline Posted January 12, 2018 Share Posted January 12, 2018 Hi all, does anyone know if the TTS decoders support firebox flicker? Has anyone tried it?I see from a previous topic the R8249 does not do this.Thanks,Mick. Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 12, 2018 Share Posted January 12, 2018 There isn’t any flicker built into the spare function output although you can use it to power a flickering LED circuit. Link to comment Share on other sites More sharing options...
Chrissaf Posted January 12, 2018 Share Posted January 12, 2018 The TTS decoder is a basic decoder. It does not have a built in 'flicker' circuit. It does however have one AUX output (continuous when enabled) that could potentially be wired to an external LED flicker circuit. Link to comment Share on other sites More sharing options...
thirdline Posted January 12, 2018 Author Share Posted January 12, 2018 Thanks for the replies guys. I have since searched the net and found a 5mm Flickering Pre-wired LED, is this the sort of thing you mean? I think 5mm is a bit big for a firebox glow but I'm sure I could work round that. What colour wires from the TTS would I need to use and which one would need the resistor?Thanks again,Mick. Link to comment Share on other sites More sharing options...
96RAF Posted January 12, 2018 Share Posted January 12, 2018 MickResistor can go in either leg of the led but you need the anode connected to the decoder blue and the cathode connected to the decoder green. Then for a steamer you switch it using F18 or for a diesel using F25. These will have to be hard wired to the socket pins if the loco has one or by splicing into the decoder harness if not in the usual fashion. A1K Ohm resistor should be adequate but you may have to alter this value to get the brightness and/or flicker rate you want, just be carefull to keep the current load down below 100mA. Rob Link to comment Share on other sites More sharing options...
Howbi Posted January 12, 2018 Share Posted January 12, 2018 These flickering leds are available here... http://www.layouts4u.net/leds.html .....they are pre-wired with built in resistor ready for a 12volt DC connection as described by RAF96 above......./media/tinymce_upload/cec635639112b09b4b161fd7b3f87b47.jpgNOTE......the bottom detail says Yellow but in fact these are the RED ones as per code FL4R....HB Link to comment Share on other sites More sharing options...
Alan K Posted January 12, 2018 Share Posted January 12, 2018 I have used the 3mm LEDs available here with a TTS decoder - also 5mm and prewired availablehttp://bright-components.co.uk/epages/950004269.sf/en_GB/?ObjectPath=/Shops/950004269/Categories/LEDs/Flashing_LEDs/Ultra_Bright/%223mm%20Flickering%22Or via Ebay Link to comment Share on other sites More sharing options...
thirdline Posted January 14, 2018 Author Share Posted January 14, 2018 The LED's with the resistor fitted sound attractive, would the wire with the resistor fitted go to the green or the blue decoder wire?i guess once fitted it would be a simple case of enabling the flicker via F18 then enabling the coal shovelling.i can't waitThanks guys,Mick. Link to comment Share on other sites More sharing options...
96RAF Posted January 14, 2018 Share Posted January 14, 2018 The LED's with the resistor fitted sound attractive, would the wire with the resistor fitted go to the green or the blue decoder wire?I said before about which wire goes where.Rob Link to comment Share on other sites More sharing options...
Howbi Posted January 14, 2018 Share Posted January 14, 2018 Since we don't know whether the resistor is on anode or cathode you will have to test for yourself possibly with a battery........when you establish the positive lead connect that to the Blue......HB Link to comment Share on other sites More sharing options...
96RAF Posted January 15, 2018 Share Posted January 15, 2018 That is essentially what I said HB.Rob Link to comment Share on other sites More sharing options...
thirdline Posted January 15, 2018 Author Share Posted January 15, 2018 The LED's with the resistor fitted sound attractive, would the wire with the resistor fitted go to the green or the blue decoder wire?I said before about which wire goes where.RobAh, sorry for not paying attention. Now I understand that the anode and cathode are on the LED not the resistor how do I go about finding out which is which?Thanks,Mick Link to comment Share on other sites More sharing options...
Chrissaf Posted January 15, 2018 Share Posted January 15, 2018 how do I go about finding out which is which?.Howbiman explained how to do this in the last post on the previous page..To reiterate what HB wrote again, connect the LED WITH ITS RESISTOR IN CIRCUIT to a 9 volt battery. The LED will only light up when the anode is connected to the battery positive. There is no hard and fast rule on this, but most LED sellers that sell pre-wired LEDs with pre-fitted resistors, usually put the resistor in the positive wire leg of the LED. But as I just said, this sellers construction practice cannot be guaranteed, so it is always best to check the polarity with a battery. Not only that, but it tests the LED as being functional before wasting time installing a faulty one. You MUST include the resistor in the battery test circuit and in the final installed circuit, else you will burn out the LED. Link to comment Share on other sites More sharing options...
thirdline Posted January 15, 2018 Author Share Posted January 15, 2018 Thanks Chrissaf for your informative reply, I'm clear on what to do now.Thanks again,Mick. Link to comment Share on other sites More sharing options...
96RAF Posted January 16, 2018 Share Posted January 16, 2018 3rdLYou can download datasheets for leds from the likes of RS Components or Maplins and these show the physical and electrical characteristics of the item. You need these when starting out as part of the learning curve. If you want a good free book about model railway electronics you can download one from the home page of the MERG web site. Well worth a read and keeping as a reference. Rob Link to comment Share on other sites More sharing options...
