Craigbc Posted January 14, 2018 Share Posted January 14, 2018 I can’t seem to get the false start/reaction time to work. Any ideas. Link to comment Share on other sites More sharing options...
woodcote Posted January 14, 2018 Share Posted January 14, 2018 Can you tell us which ARC powerbase you are using? Is the finish line working? Thanks. Link to comment Share on other sites More sharing options...
Andy P. Posted January 14, 2018 Share Posted January 14, 2018 ARC ONE/AIR and PRO all handle the drag race slightly differently. We need more info... Link to comment Share on other sites More sharing options...
Craigbc Posted January 16, 2018 Author Share Posted January 16, 2018 I’m using arc air pro Link to comment Share on other sites More sharing options...
Craigbc Posted January 16, 2018 Author Share Posted January 16, 2018 I’m using arc air pro, finish line works most of the time Link to comment Share on other sites More sharing options...
Andy P. Posted January 16, 2018 Share Posted January 16, 2018 Either you have ARC PRO (digital) or ARC AIR (analog) whereby the ARC PRO acts the same as ARC AIR in analog mode.False starts are only recorded when the Start mode is set to "Live". Link to comment Share on other sites More sharing options...
BN_Racer Posted March 2, 2019 Share Posted March 2, 2019 I having the same problem. I have ARC One. Is there no jump start or reaction time? The finish does work. That’s it. Link to comment Share on other sites More sharing options...
woodcote Posted March 3, 2019 Share Posted March 3, 2019 Hi BN_Racer. It is a while since I used ARC One, but I seem to remember that there is no false start detection on the drag race mode. That’s probably because the ARC component of the power base is a passive lap counter - there’s no two-way control of the track power as there is with ARC Air and Pro. It looks like it should - there Is the throttle bar in the app display - but that seems to be mere window-dressing. The reaction time on a standard race in ARC One is the time between the green light and the car triggering the powerbase sensor. I guess the only work around is to have a clear drag strip start line and a third person to adjudicate - or to video the start. That might make the drag race even more tense! Link to comment Share on other sites More sharing options...
