atmhobby Posted February 17, 2018 Share Posted February 17, 2018 Hi everyone,Sometimes while we are driving the cars will surge suddenly. Does anyone know what causes this?Also, what do you guys use to clean the metal slot on your track? Mine are starting to turn a little bit gray.Thanks! Link to comment Share on other sites More sharing options...
woodcote Posted February 17, 2018 Share Posted February 17, 2018 Hi atmhobby. The surges are most likely because the track isn't clean. If the chip can't get a clear signal from the track (ie the digital instructions from the powerbase), it thinks it is in analogue mode and momentarily goes to full throttle. Of course, dirty braids can cause this problem too. I use a couple of drops of Inox MX3 on the braids of a car at the start of a session. I run the car round a few laps and the Inox does the job. Most digital racers use Inox. If you are in Australia, NZ, the USA or Canada, Inox is easy to get. In Europe it is tricky to find. Sometimes there is a group order to the UK organised on Slot Forum. However, a small bottle will last a long time and is a good investment. I have the 60ml bottle with the needle nozzle. In the meantime, some lighter fuel (the rectangular tin) is a good traditional rail and braid cleaner. Use it on a rag and don't smoke while you're using it! Have fun 😀 Link to comment Share on other sites More sharing options...
atmhobby Posted February 17, 2018 Author Share Posted February 17, 2018 Thanks so much for the advice! I will try it this weekend. Link to comment Share on other sites More sharing options...
gorp Posted February 19, 2018 Share Posted February 19, 2018 never have used inox - used tiger milk occasionally for decades and kept track clean and covered when not in usewhile using light application of vasoline on rail connectors when assembling over using jumpers in early days the early dpr chips were famous for surgingstill have a couple as spares only till replacement can be purchased today have found 99% of toy surging is improperly assembled 2 piece guidesfrom accidents and racers at the start that pull car backwards to line them upcorrection is just proper reassembly - info believe is included in every car sold and sets Link to comment Share on other sites More sharing options...
