andrew_ball1 Posted March 10, 2018 Share Posted March 10, 2018 Are all current cars availlable new from Scalextric digital ready? Link to comment Share on other sites More sharing options...
woodcote Posted March 10, 2018 Share Posted March 10, 2018 If you mean are they all 'Digital Plug Ready' (DPR), the answer is no. That should be clearly stated on the website for each individual car. Most are, but the Legends Formula One cars and front-engined classic cars (eg Corvette Stingray, E-Type Jag) are not. This is because there is no space to fit the digital plug in the chassis. A few others, such as the Super Resistant LMP, GT Lightning and Team Rally cars are not either - not sure why they aren't DPR, except they were all originally made for the cheap entry-level Start sets. If you mean can all current Scalextric cars be converted to digital, then that is a yes. Cars that aren't designated DPR can be fitted with a C7005 Retro-Fit chip. This requires some basic soldering skills and a 3mm hole may need to be drilled in the chassis - full instructions come with the chip. The challenge with the Legends F1 and front-engined classic cars is to find room in the cars to place the chip. With the Legends F1 cars, that will mean significant modifications to the cockpit and driver to make room. Hope that helps Link to comment Share on other sites More sharing options...
andrew_ball1 Posted March 10, 2018 Author Share Posted March 10, 2018 Thanks Woodcote that answrs my question.Next question: Will digital cars run on ARC AIR tracks and will analog cars run on ARC PRO tracks? Link to comment Share on other sites More sharing options...
woodcote Posted March 11, 2018 Share Posted March 11, 2018 Yes, cars with the Scalextric digital chips will run on traditional 'analogue' track, including ARC Air. And yes, ARC Pro has an analogue setting (there's a switch on the side of the powerbase) which means you can run the powerbase as if it were an ARC Air base (the app also runs in ARC Air mode). Scalextric have generally been very good with their design philosophy to ensure digital / analogue compatibility. However... I'm not a fan of running digital cars on any analogue track, they feel very jerky to me. There's not the smoothness of running analogue on analogue. Similarly, I'm not grabbed by the analogue mode on ARC Pro. Power is delivered in a different way to ARC Air, and it's not as smooth. The cars and the powerbase make quite a loud noise too, which some people find alarming! I'm lucky to have ARC One, ARC Air and ARC Pro powerbases. Mostly I run digital, but since ARC came out, the old 70s and 80s Scalextric cars of my childhood have got a new lease of life with the ARC app. If I just want to run a few laps, analogue mode on ARC Pro is okay. If I want a serious analogue racing session, then I swap out the ARC Pro powerbase, pit lane and lane changers and hook up ARC Air. Link to comment Share on other sites More sharing options...
Andy P. Posted March 12, 2018 Share Posted March 12, 2018 Digitally chipped cars on an analog track do not have brakes making them a little harder to handle... on DPR cars you can take the chip out easily getting brakes back.. Link to comment Share on other sites More sharing options...
Twigman Posted March 12, 2018 Share Posted March 12, 2018 NOTEI tend to convert non-DPR cars using a SureChange guide that places the IR LED in the guide rather than have to drill a hole in the chassis. This places the IR LED in front of the guide blade. It also means that no matter how sideways the car gets the LED is over the sensor.I am informed that this configuration will NOT work with ARC Pro as ARC-Pro needs both the blade AND the LED (IN THAT ORDER) to cross the finish line to register a lap. Another reason I shall NOT migrate to ARC-Pro. Something tells me engineers at Scalextric didn't think this through Link to comment Share on other sites More sharing options...
woodcote Posted March 12, 2018 Share Posted March 12, 2018 I have a car with the SureChange guide fitted, but I don't think I have used it with ARC Pro as yet. I will dig it out later and try. I'm pretty confident it will work, since the sensor set-up in the ARC Pro powerbase is similar to the C7042 Advanced Powerbase. Optional firmware upgrades in the APB did away with the need for both the guide sensor and the ID sensor to be involved in counting laps. The guide sensor (on both ARC Pro & APB) is, as far as I understand, to allow lap counting in analogue mode. The ability to use a digital powerbase with non-digital cars was (and still is) an important compatibility issue for Scalextric, which is fair enough. I'll test later and let you know whether it works or not. Of course, the SureChange guide is not a Scalextric product and it is pretty niche within the Scalextric digital community, only being available via private message on Slot Forum... It is very handy for non-mag racing where getting a bit sideways is de rigueur. It is also my go-to solution for the front-engined cars (in my case a Revell Cobra Daytona) where the motor is sitting where the LED would normally go. Link to comment Share on other sites More sharing options...
Twigman Posted March 12, 2018 Share Posted March 12, 2018 woodcote - slotforum reports that ARC-Pro will not count laps if the the LED is in front of the blade. Surechange guides are not solely available via PM on slotforumThey are available at https://www.slotcar-union.com/en/slotcar-tech/1762-surechange-racing-guide-fixing-screw.html for example Link to comment Share on other sites More sharing options...
woodcote Posted March 12, 2018 Share Posted March 12, 2018 I tried my Cobra Daytona with the SureChange guide on ARC Pro and you're absolutely right, it didn't register laps. I put the car through the powerbase backwards and it did register, so ARC Pro does seem to require guide then ID. I don't have an APB with the original firmware to see if there is the same issue. I suspect it might be. That's a shame, as the SureChange guide is a nicely thought-out innovation for digital racers. However, it remains 100% compatible with the C7042 APB with updated firmware, which most Scalextric digital enthusiasts will be sticking with for the forseeable future. Good to see Slot Car Union is now selling the guide. I guess there are two possible scenarios where the guide might still come into play on ARC Pro. The first is if an optional digital-only firmware upgrade becomes available - as it did with the APB, thanks to co-operation between third-party RMS developers and Scalextric. Alternatively, the same ingenuity that produced the SureChange guide in the first place could create an ARC-friendly version. For those getting into digital via ARC Pro, I'm not sure the incompatibility of the SureChange guide will be a deal-breaker. Having said that, I think it shows the need to find an alternative fix to convert those front-engined cars and the Legends F1s. That probably falls to the 3D printers to create digital-compatible chassis and cockpits to use with the standard Scalextric components (rather than needing additional Slot.it components). Incidentally, the reason my Cobra hadn't been used with ARC Pro is that I'm converting it with an Olifer 3D chassis with a standard LED fitting. I really like all the aftermarket options that exist at the moment. It goes to show that the big manufacturers (essentially Scalextric and Carrera now) give us a product and some very clever enthusiasts come up with brilliant tweaks that occasionally take the hobby down new paths. It's great that some of those ideas get taken up by Scalextric and other manufacturers, but ultimately they have to make compromises to bring a good-value and profitable product to market. Link to comment Share on other sites More sharing options...
Twigman Posted March 12, 2018 Share Posted March 12, 2018 , it remains 100% compatible with the C7042 APB with updated firmware, which most Scalextric digital enthusiasts will be sticking with for the forseeable future. Until such a time as ARC-Pro has single sensor registration ( and CLC compatibility) I can't see anyone migrating from C7042 to ARC-Pro....nobody wants to reconfigure their converted digital cars. Have Scalextric really thought the ARC-Pro through properly?They seem to continously make product incompatible with product that's gone before. Why?While I know that the Surechange guide wasn't a Hornby invention, they must realise it exists and many cars have been converted to use it. The fact that ARC-Pro isn't compatible merely puts people off.As if the CLC compatibility thing wasn't enough.I'm not sure that's a particularly clever strategy. Link to comment Share on other sites More sharing options...
Andy P. Posted March 13, 2018 Share Posted March 13, 2018 They seem to continously make product incompatible with product that's gone before. Why? Try putting a 5 1/4" disk into any computer made in the last 10 years.. or even a 3 1/2" disk for that matter.When resources and budget are tight you have to make compromises. The curved lane changers have not been part of the catalog for quite some time and as you say SureGuide is not an official product. Carrera for example for years had no way of running the same powerbase in analog and digital mode without making soldering modifications.The fact of the matter is that all cars and all pieces of track in the current catalog work with ARC PRO as designed.Luckily, thanks to the efforts of enthusiasts things can be vastly approved.Believe my anything posted here is read by Scalextric and taken into consideration.My personal request is to be conscience that anything posted here is read by the whole world and that any criticism levied should constructive. Link to comment Share on other sites More sharing options...
Twigman Posted March 13, 2018 Share Posted March 13, 2018 My personal request is to be conscience that anything posted here is read by the whole world and that any criticism levied should constructive.Scalextric have taken a step backwards here.How am I not being constructive?Single sensor registration is a better system, surely - why wouldn't they have adopted it with ARC-Pro? Link to comment Share on other sites More sharing options...
Andy P. Posted March 13, 2018 Share Posted March 13, 2018 Scalextric have taken a step backwards here.That is your personal opinion and seems to be based on the assumption the ARC PRO is the new C7042.That, to my knowledge has never been stated by anyone at Scalextric and may not been be their intention.Saying something is "worse" are questioning whether people "know what they are doing" is not constructive. Link to comment Share on other sites More sharing options...
woodcote Posted March 13, 2018 Share Posted March 13, 2018 As I said in an earlier post, the guide + ID sensor lap counting is a compromise that allows both digital and analogue use - something that Scalextric are keen to offer to their customers. Although the analogue mode in ARC Pro might not be perfect, it is a welcome option for most people. As Dr_C has written here and on Slot Forum, the way Scalextric have squeezed analogue and digital into ARC Pro is clever. He's also looked closely at the components and reckons ARC Pro offers the best quality of any SSD powerbase so far. However, the compromise of this cleverness and of offering a premium digital powerbase to all digital users (in contrast to the 4-car pb...) plus the wonderful ARC Air analogue functionality is the issue of keeping both lanes of the powerbase electrically isolated. In order to use the old curved lane changers, single lane sections and an odd number of cross overs, users need to carry out some modifications. Again Dr_C has helpfully outlined how to do these. For me his solution of adding a 'deadstrip' half straight either side of the powerbase is both neat and comprehensive. At the end of the day, Scalextric has given us a new system. Opinion is divided, as it always is by new things. I was blown away by ARC One and ARC Air but was a little nervous about ARC Pro, being familiar with running all the add-ons to the APB. When I gave it a go, I was very pleasantly surprised. It might have been a long time coming, but I think Scalextric have done a good job and opened up a quality digital system to a much wider audience. Link to comment Share on other sites More sharing options...
