happy chap Posted March 15, 2018 Share Posted March 15, 2018 hello ,Ive recently set up the pendolino/ dcc select that i purchased in 2008,when train comes off track ,it will set off at fast speed when put back on again, even though speed setting is on slowAny advice /help appreciated Link to comment Share on other sites More sharing options...
Howbi Posted March 15, 2018 Share Posted March 15, 2018 @happy Chap, welcome to the Forum........have you tried re-setting the Select?........HB/media/tinymce_upload/d0fefeb69659189cfca6a2c772906926.jpg Link to comment Share on other sites More sharing options...
happy chap Posted March 15, 2018 Author Share Posted March 15, 2018 hello howbiman,ive reset still same problem ,when it goes off at full speed it dosnt respont to controls or emergency stop. Link to comment Share on other sites More sharing options...
Flashbang Posted March 15, 2018 Share Posted March 15, 2018 HiThe loco decoder is I feel either defective or more likely is 'seeing' the full rail volts always present regardless of actual speed setting on the DCC console. Rail volts are typically 13 to 15 volts. It then speeds off at full top speed thinking the rail volts are DC full power.The way to stop this is to alter a CV setting to turn off the DC operation mode- CV29 setting it to a value of 2 or 34 where long four digit addressing is used. Unfortunately AFAIK the Select cannot do this alteration, so you would have to find someone with a more up market DCC system and get them to turn off the DC operation. Link to comment Share on other sites More sharing options...
96RAF Posted March 15, 2018 Share Posted March 15, 2018 It sounds like DC runaway to me, which as FB says you can’t adjust for with a Select at present time, but you can select loco zero (analogue loco) and move the speed knob up and back firmly to stop. If loco zero (even if you don’t have one) is throttled up it can affect DCC locos. Worth trying it.Rob Link to comment Share on other sites More sharing options...
Fishmanoz Posted March 15, 2018 Share Posted March 15, 2018 Should have been fixed by resetting the Select? Link to comment Share on other sites More sharing options...
96RAF Posted March 16, 2018 Share Posted March 16, 2018 Should have been fixed by resetting the Select?True Fishy. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted March 16, 2018 Share Posted March 16, 2018 I think you've all missed this important bit - purchased in 2008TEN year old brand new Select - badly needs updating! You will have to send it back to Hornby, as Select cannot be updated on-line.Also -it will set off at fast speed when put back on again, even though speed setting is on slow. - - You MUST turn the speed controller right down to ZERO before re-railing, or the decoder will 'see' corrupted data, switch to dc mode - and it will take off like a greyhoud out of the trap. Link to comment Share on other sites More sharing options...
happy chap Posted March 17, 2018 Author Share Posted March 17, 2018 Thanks for all advice ,Iv tried all your suggestions no joy ,so now im waiting for reply from hornby about updateing .keep the hobby moving ,onward and upward. Link to comment Share on other sites More sharing options...
