Ashbourne Junction Posted March 18, 2018 Share Posted March 18, 2018 Hi. Has anyone had any success converting the City of Leeds Duchess (as in the Middy Scot set) to DCC? i couldn’t find anything through the search or elsewhere. I know its probably pre DCC, but just wondered. Thanks for any advice. Link to comment Share on other sites More sharing options...
WilliamDavid Posted March 18, 2018 Share Posted March 18, 2018 This may be non dcc or dcc ready. I think it came in both versions.You need to take the loco body off and see if a 8 pin decoder is fitted.If one is fitted, easy.If not, you will have to hard wire the decoder. Link to comment Share on other sites More sharing options...
96RAF Posted March 18, 2018 Share Posted March 18, 2018 If you know the catalogue R- number then you can find the service sheet for it which will show if there is a socket or not and/or where it is. Link to comment Share on other sites More sharing options...
Ashbourne Junction Posted March 18, 2018 Author Share Posted March 18, 2018 Thanks. Looks like it is r2078 which equates to service sheet 223. No mention of dcc unfortunately. Link to comment Share on other sites More sharing options...
Fishmanoz Posted March 18, 2018 Share Posted March 18, 2018 Or SS111 for that R number. Either way, it is a Ringfield tender drive. Check Brian Lambert for which of the 3 types is in it and how to convert it. You must first make sure the brush connectors are isolated from the chassis. Link to comment Share on other sites More sharing options...
tnttrucker Posted March 18, 2018 Share Posted March 18, 2018 I have this model from the Royal Scot train pack. It has a Ring field tender drive motor and it was a hardwire job. I had to replace one of the screws holding the brush and spring in place with a nylon screw (got from Peters spares)in order to isolate it from the motor/tender chassis. It was then just a soldering job. There is room in the tender for chip to fit, I used double sided sticky tabs. Link to comment Share on other sites More sharing options...
Ashbourne Junction Posted March 18, 2018 Author Share Posted March 18, 2018 Really helpful everyone. Thankyou. It can be done then. Link to comment Share on other sites More sharing options...
