gragrahadea Posted March 31, 2018 Share Posted March 31, 2018 hi there is anew bachmann 9f evening star coming out,with a8 pin decoder socket ,can a hornby tts decoder be fitted into it,are they compatable. Link to comment Share on other sites More sharing options...
Chrissaf Posted March 31, 2018 Share Posted March 31, 2018 Basically the same answer to those you got with these same/similar questions:.https://www.hornby.com/uk-en/forum/tts-decoders-22422/?p=1/#post-240734.https://www.hornby.com/uk-en/forum/hornby-tts-decoders/?p=1/#post-240719.https://www.hornby.com/uk-en/forum/hornby-decoders-22049/?p=1/#post-239388.With respect, you can ask the same question as often as you like, but it is unlikely to illicit a different answer to ones already given..The fact that this new 9f will have an 8 pin socket (if you say so) is immaterial, many here have fitted TTS decoders to Bachmann 21 pin locos using Bachmann's own 21 pin to 8 pin adaptor. Thus fitting it to a natively 8 pin loco will be even easier. As other's have said in the replies linked above. It's all down to the speaker and the physical space to fit it. With a high probability that the supplied Hornby speaker will need to be replaced with a smaller sugarcube alternative..R8113 9f TTS Decoder. Has got quite a large round speaker that looks to be designed for Tender located decoder and speaker. So if the Bachmann has a loco located decoder socket (more likely), then you will more than likely need either a new smaller speaker to go in the loco or extend the Hornby one into the tender subject to space and speaker mounting suitability. Link to comment Share on other sites More sharing options...
Howbi Posted March 31, 2018 Share Posted March 31, 2018 Thought I had answered this same question twice before..........HB Link to comment Share on other sites More sharing options...
Fishmanoz Posted March 31, 2018 Share Posted March 31, 2018 It’s Easter HB, answer it again, then Chris will have 4 links to pass on to the next/same person asking the question again. Link to comment Share on other sites More sharing options...
96RAF Posted April 1, 2018 Share Posted April 1, 2018 Maybe on this auspicious date the answer could be modified to suit. Tomorrow I may change my advice.Yes you can fit an 8 pin decoder to a 9F but you may have to tape the speaker on top of the boiler.Rob Link to comment Share on other sites More sharing options...
2e0dtoeric Posted April 1, 2018 Share Posted April 1, 2018 Or - just cut the wires to the speaker. That will make the loco run more quietly! 😛 Link to comment Share on other sites More sharing options...
